intake air temperature wiring
Old Nov 26, 2002 | 01:59 AM
simple4012's Avatar
New User
Default intake air temperature wiring
hey guys...anyone know the wiring for an Intake air temperture sensor? I need to move mine to the intake manifold and the wires are different colors....thanks guys
Old Nov 26, 2002 | 12:28 PM
Kataku2K3's Avatar
Default Re: intake air temperature wiring (simple4012)
Are you just wiring the IAT into the manifold mount style??? If you do that it shouldn't matter... There is no polarity on the sensor itself... All the IAT does is create resistance relative to temperature.. Latez
Old Nov 26, 2002 | 12:31 PM
brcivic411's Avatar
?? do you mean you're using a different sensor? if you're just moving the sensor from one location to the other, wouldn't that mean all the wires stay in place?
Old Nov 26, 2002 | 01:02 PM
Nameless RB26's Avatar
Default Re: intake air temperature wiring (brcivic411)
You gotta be more specific about things. What color wires? What engine harness? Pretend people don't know anything about your setup if you want help like this..
The wiring for an IAT? There is no in depth wiring about this, it only has two wires coming out of the plug. And if you're just moving it, then extend the wires...
Old Nov 26, 2002 | 04:59 PM
Kataku2K3's Avatar
Default Re: intake air temperature wiring (Nameless)
There is not anything too complicated about this... He prolly has an IAT that mounts into the intake tube itself as on a 99-2000 Si or in the box above the TB on the 96-2000 CX/DX.... It has a little different kinda connector which makes it so that you can not plug it on to a normal intake manifold mounted IAT... Like I said don't even worry about the color of the wires.. Just extend them with the plug you need.. Good Luck..
[Modified by JDMspecEG6, 6:01 PM 11/26/2002]
Tippyman
Dec 31, 2005 10:29 AM
DxBurnoutKing
Apr 27, 2005 08:50 AM
97VtecIN
Nov 13, 2004 12:36 AM
RuffRhyno
Aug 13, 2004 09:37 AM
RuffRhyno
Aug 12, 2004 05:50 PM
