When taking off hondata, does ECU need to be modified to wrk correctly again?
Old Nov 29, 2002 | 11:38 AM
VTEC-DA's Avatar
Default When taking off hondata, does ECU need to be modified to wrk correctly again?
I have a OBD1 P28 ECU w/ and OBD2-1 conversion harness on my car. I removed the hondata 2b, simply by unplugging the little clip, do I need to do anything else for the ECU to work correctly. I only ask because I can read the CEL codes now and I figured this might be why?
Old Nov 29, 2002 | 02:40 PM
VTEC-DA's Avatar
Default Re: When taking off hondata, does ECU need to be modified to wrk correctly again? (non-turbo2dr)
Old Nov 29, 2002 | 03:33 PM
b19coupe's Avatar
Remove the jumper at J1 and the ECU will run the stock program.
Old Nov 29, 2002 | 04:08 PM
VTEC-DA's Avatar
Default Re: When taking off hondata, does ECU need to be modified to wrk correctly again? (b19coupe)
Jumper at J1? IS that a pin out or is that inside the ECU itself? I took off the wire and connector that ran inside the ECU, but my car is running shitty and the ECU wont let me pull the codes, so I think something is wrong with it.
Old Nov 29, 2002 | 04:15 PM
b19coupe's Avatar
J1 is inside the ECU. Do you have Adobe Acrobat ? If so, download the Hondata installation manual from the Hondata website and you will be able to see exactly what to do in order to return the ECU to stock.
Old Nov 29, 2002 | 05:51 PM
DragII's Avatar
25 Year Member
check out http://www.hondata.com they have some diagrams/pics...also remember that the ecu I had in the car is OBDI, not OBDII, so you will need to do keep the harness in as well.
you might want to get in touch w/ steve sakai, he can put it back to stock for ya for like 50 bucks er so.
vy3tnamezz
Engine Management and Tuning
Sep 20, 2009 10:43 AM
asc
Aug 14, 2008 08:39 PM
amalby
Apr 22, 2008 08:35 PM
trick_db
Apr 30, 2006 09:10 AM
NuclearB18B
Sep 19, 2003 04:15 PM
