Open Header at the flick of a switch...cool!
Old Nov 28, 2002 | 10:18 AM
satan_srv's Avatar
Default Open Header at the flick of a switch...cool!
Here is the switch controlled open header setup I made:
This Ghetto mod is brought to you by:
1) DC CC header hacked off at the flex pipe
2) A civic/Integra Ball/Spring joint
3) Electric Cutout from http://www.quicktimeperformance.com
I go from vroom to BOOOOOM in about 4 seconds.
Old Nov 28, 2002 | 10:23 AM
Nameless RB26's Avatar
Default Re: Open Header at the flick of a switch...cool! (satan_srv)
haha coool
Old Nov 28, 2002 | 10:25 AM
rolow's Avatar
I have been thinking about using the Quicktime cut out but why did you not use the normal cut out ? Like the one you can get from Quicktime?
Also how much does the solinoid weigh? I was concerned about the weight of the solinoid do you think it will be a problem?
Old Nov 28, 2002 | 10:31 AM
satan_srv's Avatar
Default Re: Open Header at the flick of a switch...cool! (rolow)
Didn't think of getting it for some reason, and my DC had a separated flex pipe...so I wanted to hack it off, and I was concerned about clearance...and flanges are chevy ones...I may get it if I don't think I'm getting enough flow...but from what I tested before it seems to flow a ton...
It's not that heavy...it's made out of aluminum..maybe 3-4 pounds?
[Modified by satan_srv, 2:31 PM 11/28/2002]
Old Nov 28, 2002 | 11:00 AM
rolow's Avatar
Cool Thanks
Old Nov 28, 2002 | 12:32 PM
TruePlayaz114's Avatar
this may be a stupid ? but what's the point in doing that?
Old Nov 28, 2002 | 12:40 PM
satan_srv's Avatar
Default Re: Open Header at the flick of a switch...cool! (TruePlayaz114)
Okay, think about disconnecting your cat, and entire exhaust system. No more restrictive flow, that's what this does.
Old Nov 28, 2002 | 01:32 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
that's pretty innovative
Old Nov 28, 2002 | 01:40 PM
Lamchop0000's Avatar
how does it proform? i figure it wont be too good since the exhaust gases are lazy and take the easy way out, straight through the exhaust system. but whatever
Old Nov 28, 2002 | 02:20 PM
satan_srv's Avatar
Default Re: Open Header at the flick of a switch...cool! (lamchop0000)
At idle if you open it lots of gas comes out. I was actually surprised...we'll see when I get the motor back in..
Old Nov 28, 2002 | 02:51 PM
Kataku2K3's Avatar
Is that mechanical or do you have an electronic solenoid?? If it's electronic you should wire it up so that it opens up with your VTEC, if you got a VTEC motor... That would scare the hell out of me if you opened up next to me.. hehe.. Nice work tho..
Old Nov 28, 2002 | 02:55 PM
R@mon's Avatar
Default Re: Open Header at the flick of a switch...cool! (JDMspecEG6)
that looks like it would help alot but i think if it was a v instead of a almost 90 degree bend/curve it would flow better.....let us know how it turns out... sounds good.....
Old Nov 28, 2002 | 04:05 PM
CHEETAH's Avatar
what i usually do for customers is use the summit racing one which has a cable lever to pull open and its a "Y" pipe that you put in place after collector/before cat.
Years ago I used one of these with a mitsu solenoid and opened the plate when VTEC kicked in, sounded so badass, people said I had NOS cause VTEC kicked "so hard"
JC Whitney sells these pipe collectors the cheapest I've found.
greg
Old Nov 28, 2002 | 04:10 PM
kb58's Avatar
Banned
Default Re: Open Header at the flick of a switch...cool! (dLo GSR)
You mean like the same thing they had in the 50's?
Old Nov 28, 2002 | 04:12 PM
Kataku2K3's Avatar
Default Re: Open Header at the flick of a switch...cool! (CHEETAH)
haha, i bet it would that's what i was saying.. All quiet then VTEC all the way up... I've seen those summit ones but that just seems kinda ghetto... I like the electronic solenoid type.. hehe
B18C_EJ8
Dec 8, 2006 05:10 AM
broketuner-Sol_Si
Mar 20, 2006 10:57 PM
slowdelsol
Acura TSX
Jun 20, 2004 06:40 AM
bowhunter
May 5, 2003 09:25 AM
