IDLE problem with a chipped p28
Old Nov 28, 2002 | 06:04 PM
JdoggsGSR's Avatar
New User
Default IDLE problem with a chipped p28
Hey was up i have a 99 GSR i converted from OBDII to OBDI and im running a chipped P28 with the Skunk2 program and my car idles around 700 and lower how can i fix that???
Old Nov 28, 2002 | 06:13 PM
eg6ajk's Avatar
Default Re: IDLE problem with a chipped p28 (JdoggsGSR)
on the Throttle Body, there is small sized screw switch controls the idle speed.
Old Nov 28, 2002 | 07:45 PM
JdoggsGSR's Avatar
New User
Default Re: IDLE problem with a chipped p28 (eg6ajk)
Yeah i tried that and nothing happened??
Old Nov 28, 2002 | 10:03 PM
Newman's Avatar
New User
If it's just idling low (and not jumping around), then just adjust your throttle cable with a 10mm wrench on the throttle cable bracket, on the manifold. That'll give you more play and then fine-tune it with the idle screw on the TB.
If your idle is jumping around from like 400-1000 rpms, then you either have a vacuum leak or a bad chip in your ECU (or bad soldering job of the chip and it's components).
john159753
Apr 26, 2013 10:35 AM
preludedriva
Dec 22, 2006 01:12 AM
Slimm-rw-
Mar 26, 2005 11:45 PM
vtecmike1
18
Feb 13, 2005 01:57 PM
Chris N
Dec 4, 2003 09:40 AM
