what would cause this...o2 sensor problem
Old Nov 26, 2002 | 11:37 PM
HondaCutter's Avatar
Default what would cause this...o2 sensor problem
I have an autometer a/f gauge and an apex turbo timer reading voltage on the o2 sensor. Sometimes the a/f gauge works right, and the tt shows the voltage fluctuating between 0 and 1 volt. But most of the time, usually after some driving, the a/f gauge stops working correctly, and the tt starts reading between approximately .5 to 1.4 volts. What would cause this, I've been through 2 o2 sensors now (both were used though) but I find it odd that both would do this. Are there any other sensors that could go bad and cause this?
I have a 92 civic dx w/97 LS motor with 95 LS ecu.
Drag 3 turbo kit, with walboro 255 lph fuel pump and vortech fmu as my fuel management.
Any help is greatly appreciated.
Also, I have no catalytic converter, just a cheap flexpipe that I got from autozone.
Old Nov 27, 2002 | 06:32 AM
Default Re: what would cause this...o2 sensor problem (HondaCutter)
bump
hybridb18
Feb 7, 2005 06:52 AM
xrocket21
Oct 23, 2004 08:43 AM
photonjedi808
25
Apr 17, 2003 12:08 AM
HondaCutter
Nov 28, 2002 09:19 AM
hatchy
Aug 23, 2002 10:41 PM
