MSD or hondata rev limiter ?
Old Jul 24, 2002 | 06:16 PM
salt's Avatar
Default MSD or hondata rev limiter ?
Right now I'm using the hondata rev limiter, before I had that I used the MSD. It seemed like the MSD had a more 'level' limiting, while the hondata seems kind of bouncy. Is one better than the other ?
Steve
Old Sep 29, 2002 | 06:20 PM
Brian_92GSR's Avatar
New User
Default Re: MSD or hondata rev limiter ? (salt)
Use the MSD. The hondata only cuts fuel, which isn't a very good way to do it. The MSD cuts ignition.
Old Sep 29, 2002 | 08:06 PM
HotRodTeg's Avatar
Default Re: MSD or hondata rev limiter ? (Brian_92GSR)
Hey I have a question when you use your hondata rev limiter do you have to press the botton then put the rpms where you want it the step on the brakes every time you line up to the line?
Old Sep 29, 2002 | 09:02 PM
The_Head's Avatar
Default Re: MSD or hondata rev limiter ? (streetracer)
No, once you set your launch RPM on the Hondata, it will remain and the set RPM level until you decide to change it again.
I'd go with the MSD limiter as mentioned before, it cuts the spark, which is better on your motor than cutting the fuel.
Old Sep 30, 2002 | 01:01 PM
salt's Avatar
thanks for the info!
delsol revolution
Jul 31, 2006 04:43 PM
pcguy760
May 4, 2005 04:56 PM
1FastCoupe
Apr 16, 2005 07:25 PM
hondaspeder
Sep 7, 2003 09:00 AM
Stroker
Mar 8, 2003 03:20 PM
