Where is the O2 sensor?
Old Jul 24, 2002 | 10:58 PM
blufke's Avatar
Default Where is the O2 sensor?
i was wondering where the first o2 sensor is on a gsr and also ls header and downpipe. i looked at a gsr header(obd2) and an ls header(obd2) and i couldnt find anywhere on the gsr header for the 02 to be but on the ls it was right before the cat. im trying to pick up a header and dpipe for my b20 swap into my eg. ill be running an obd1 ecu so i only need the first o2. but where are the o2s supposed to be on the gsr and ls?
Old Jul 25, 2002 | 12:19 AM
salbaje's Avatar
Default Re: Where is the O2 sensor? (blufke)
it is on the downpipe before the cat
Old Jul 25, 2002 | 06:02 AM
IlikeTODA's Avatar
GSR and LS headers are different. LS is about 7-8in longer and flange is turned. The bung for the LS is at the end of the header before the cat and if I'm not mistaken both the GSR O2's are in the cat. One in front and the other towards the end. I could be wrong.
Thanks, J
Old Jul 25, 2002 | 06:33 AM
jag's Avatar
jag
Default Re: Where is the O2 sensor? (IlikeTODA)
In my GSR (1996) the O2 sensors are in the cat housing. One at the beginning and one at the end.
-Jeremy
Old Jul 25, 2002 | 08:38 AM
blufke's Avatar
Default Re: Where is the O2 sensor? (jag)
so what header do you guys recommend for my b20. i dont want to spend much $$$ cuz im heading down the turbo road fairly soon.
lsvtec101
Mar 16, 2009 08:44 AM
kwu808
Nov 18, 2006 05:28 PM
Guyson
Oct 3, 2006 05:29 AM
phivelug
Jan 20, 2005 11:27 AM
h45454
May 12, 2003 02:47 PM
