vtec controller
Old Jul 23, 2002 | 08:36 AM
k193sup's Avatar
Default vtec controller
can any one briefly explain how a vtec controller works and is it true that with a vtec controller you alter when the vtec kicks in
Old Jul 23, 2002 | 09:18 AM
kinesistech's Avatar
Default Re: vtec controller (k193sup)
A vtec controller changes the signal from the tps, map, and rpm depending on what unit you have. The altered signal tells the ecu a different engine load value so it will use a different spot on its fuel map, there by increasing or decreasing fuel. When these changes are made, timing is also affected. There is no way to compensate for it. Yes, it also lets you choose vtec activation rpm.
Old Jul 23, 2002 | 10:47 AM
k193sup's Avatar
Default Re: vtec controller (kinesistech)
thanks alot for that advice
Jdmglenn
11
Sep 18, 2005 10:13 PM
Wazup
Aug 13, 2003 08:24 PM
