here is you pro-techers i hard problem
Old Jul 23, 2002 | 05:50 AM
SprayinCX's Avatar
Default here is you pro-techers a hard problem
The shop around here put on a msd ignition,blaster 2 coil,msd cap, and ngk plugs.
We replaced all the gaskets also. Here is the thing after we got it back when you rev it up it will "die" after 2000 rpms. So here is the question, WHY? It is not throwing any codes, all the wiring harness's are hooked up, and it is getting fuel.
We also thought it could be the msd ignition some we put it back to stock and
it still does the same freakin thing.
Thanks for the help.
Power
[Modified by 1slo2k1civic, 2:50 PM 7/23/2002]
Old Jul 23, 2002 | 06:27 AM
MERK1's Avatar
Default Re: here is you pro-techers a hard problem (1slo2k1civic)
You could include what kind of car it is moron. Then we might can help you with your problem.
Old Jul 23, 2002 | 06:38 AM
carolinaACCORD's Avatar
Default Re: here is you pro-techers a hard problem (MERK1)
Josh, you know what kind of car it is, answer his ?
Old Jul 23, 2002 | 07:55 AM
FSTASNTZ's Avatar
Default Re: here is you pro-techers a hard problem (GSRswapandslow)
Did they get the plug wire order mixed up?
Jason
Old Jul 23, 2002 | 08:08 AM
SprayinCX's Avatar
Default Re: here is you pro-techers a hard problem (FSTASNTZ)
no they are right we checked timing and firing order like 5 times yesterday.
unless there is a plug we over looked I'm thinking censors.
Old Jul 23, 2002 | 09:01 AM
reefer_bob's Avatar
Typically though, a bad sensor will throw a code... I'm thinking ignition of some sort. Is the idle smooth?
Old Jul 23, 2002 | 09:06 AM
SprayinCX's Avatar
Default Re: here is you pro-techers a hard problem (reefer_bob)
no, thats what i thought about the censors. I don't know. At this point i'm taking any ideas. thanks
Old Jul 23, 2002 | 02:33 PM
Chiovnidca's Avatar
Does it have spark when it acts up?
Old Jul 23, 2002 | 04:57 PM
97accordex's Avatar
Could your spark timing be way off at 2000 rpm? I wonder why it would not degrade gradually rather than cutting out right at 2k?
Check rotor position and installation. Make sure its tight. Make sure plugs are gapped properly.
Old Jul 23, 2002 | 10:10 PM
reefer_bob's Avatar
Default Re: here is you pro-techers a hard problem (97accordex)
I forget if it's possible, but make sure you don't have the Distro in 180 deg. off... The rotor is idiot proof, I forget if the distro is... I've had too many 's tonight...
Old Jul 24, 2002 | 01:08 AM
tinkerbell's Avatar
yeah the distributor key thingy only goes one way...
sounds like a poor earth in the MSD side of things...???
(maybe?)
t..
[Modified by tinkerbell, 8:10 PM 7/24/2002]
Old Jul 24, 2002 | 05:27 AM
SprayinCX's Avatar
Default Re: here is you pro-techers a hard problem (tinkerbell)
Well we took off the msd stuff and put everything in that area back to stock.
Do you think the head could be warped?
Old Jul 24, 2002 | 02:50 PM
SprayinCX's Avatar
If the head was warped to a degree that would screw up your motor that bad, it would have been visible at Harrignton's....and they had to check for trueness to mill it down anyways. Possible a cracked head, un properly gapped spark plugs, bad plug wires, burnt distributor, bad INJECTORS!!!!!!!!!!!!!!, it could be a lot of things, possibly even your computer.
You should already know what we've checked. You live ten min away from us!
Old Jul 24, 2002 | 03:27 PM
743power's Avatar
flip your map sensor and your tps, if they were removed, they look exactly the same, and are easy to mix up.
Austin's Avatar
Check all of your connectoions, and your grounds. Also check your rotor and distributor cap...
Juan_Mitosis
Mar 11, 2008 12:18 PM
Dartanian
Mar 26, 2006 06:48 PM
reed857
Aug 1, 2005 12:56 PM
carcala
Jun 6, 2002 09:53 PM
BoroDB8
Apr 18, 2002 03:26 PM
