B16 with B18C5 LSD?
Old Jul 24, 2002 | 11:39 AM
KENLUDE97's Avatar
Default B16 with B18C5 LSD?
Ok Here is the thing. I will be putting a ITR lsd in 00 Si. Now what bearing will i need? After hearing that the LSD was a direct fit, i figure that the bearing would be the same? So i could order bearing for a B16 or Type R and they will fit in the Si's Tranny?
Thank-x
KENLUDE97
Old Jul 24, 2002 | 12:48 PM
Rocket's Avatar
Default Re: B16 with B18C5 LSD? (KENLUDE97)
B16 usually have the cartridge bearings while the GSR/ITR's have the tapered roller bearings. It's easiest just to install catridge bearings on the LSD and install it.
Old Jul 24, 2002 | 12:50 PM
Rocket's Avatar
Default Re: B16 with B18C5 LSD? (Rocket)
As far as I know all the B-series hydro cases are interchangeable. So you can use GSR or B16 bearings. If you go with the GSR/ITR taper bearings you are going to have to install the outside bearings races etc.
[Modified by Rocket, 9:50 PM 7/24/2002]
Old Jul 25, 2002 | 06:21 AM
KENLUDE97's Avatar
ttt
PR8urVtec
Transmission & Drivetrain
10
Jan 29, 2016 08:19 AM
Steveeghatch
May 29, 2013 01:12 PM
powerneedy
Mar 21, 2008 05:39 AM
DaiJekBok
May 23, 2006 01:45 PM
Rhythm
Apr 23, 2006 11:12 AM
