Aligning Crankshaft before putting head on??
Old Jul 24, 2002 | 03:04 PM
shermanyang's Avatar
Default Aligning Crankshaft before putting head on??
like the question said plus how do i do it without using the crank cover? i don't know where i put it(think someone threw it away). i heard i was suppose to have pistons 1 and 4 all the way up? is that correct? help...need car up and running this weekend!!
Old Jul 24, 2002 | 03:37 PM
reefer_bob's Avatar
Default Re: Aligning Crankshaft before putting head on?? (shermanyang)
In or out of the car? Flywheel attached? Crank pully attached? What you got goin on in there?
Old Jul 24, 2002 | 04:43 PM
IN VTEC's Avatar
I guess it's the lower timing belt cover that's missing.
You can use the oil pump marking to align the crankshaft to TDC, just make sure that the pistons #1 and #4 are at TDC. Then set the cam gears to TDC #1.
Old Jul 24, 2002 | 05:38 PM
Default Re: Aligning Crankshaft before putting head on?? (reefer_bob)
the whole block along with tranny is still in the car...just the head is out. i had to take the head off due to a blown ring and decided to upgrade the rods, pistons, rings, and most of the bolts while at it. now i can't find the lower timing belt cover. stupid me!!
Old Jul 24, 2002 | 05:39 PM
Default Re: Aligning Crankshaft before putting head on?? (IN VTEC)
okay...sounds easier than it looks but i'll give it a shot. thanks!!
Old Jul 24, 2002 | 07:42 PM
GruvyTune's Avatar
New User
take a thin rod (i used a socket extension) and put it down the cylinder and turn the crank till the #1 piston is at the top. then just align the cam gears to TDC and you are set! then just put the timing belt on in that position so its tight at the front and then tighten it and you are done!
user 23852445234524
Honda CR-V & Element
Jan 26, 2016 03:46 AM
mynumer1hater
Oct 5, 2009 12:43 PM
Concept Tuning
Jun 29, 2006 06:33 PM
KL14
Nov 7, 2005 09:11 AM
94exguy
11
Jun 1, 2005 07:55 PM
