Does cam overlap affect a/f ratio?
Old Jul 23, 2002 | 10:13 AM
vtec2nr's Avatar
Default Does cam overlap affect a/f ratio?
Here's the setup
'95 GSR
CTR cams (+4 intake, -1 exhaust)
I/H/E, Random cat., Field, stock fp, stock injectors.
I'm tuning according to my a/f meter and plugs. Right now, using a Field, I am leaning out the settings across the whole range to get the desired A/F ratio(up to 10% at high RPMs). Does that seem right, or do I have too much overlap and am flowing the mixture straight through the cylinder, leaving the cylinder lean, and the exhaust rich? Is there a formula to determine maximum overlap? I'm blowing a lot of carbon out the exhaust too.
Old Jul 23, 2002 | 10:50 AM
Austin's Avatar
Default Re: Does cam overlap affect a/f ratio? (vtec2nr)
Anything that affects:
air entering
air exiting
fuel entering
fuel exiting
spark intensity
Will have an affect on your A/F ratio...some more than others.
89sicivic
Mar 8, 2006 10:18 AM
ndlyng
Dec 5, 2005 05:43 PM
fox297
Jul 17, 2003 08:13 PM
CKDC2
Apr 30, 2002 01:44 AM
93B18
Sep 18, 2001 04:05 PM
