sqeaky noise
Old Jul 24, 2002 | 09:06 AM
hmonglonertim's Avatar
Default sqeaky noise
I have a squeaky noise coming from the passenger front suspension. I've taken the wheel off, jacked it up, put the car in drive and when it spins the brake caliper is moving sideways. Could I have a bad caliper or a warped rotor. Or could it be something like wheel bearing or axle?
Old Jul 24, 2002 | 09:23 AM
moyerek's Avatar
Default Re: sqeaky noise (hmonglonertim)
if its a suspension component you should be able to reproduce the sound just by pushing down on the passenger side fender. A wheel bearing or brake problem is more of a constant sound that should only occur when the wheels are turning. A bearing or axle problem would also be more noticeable when turning.
What do you mean by the caliper is moving sideways(what is you reference frame)? When you are looking head at the wheel does the caliper move in and out or side/side?
Old Jul 24, 2002 | 09:29 AM
Default Re: sqeaky noise (moyerek)
Looking from the front of the vechicle the caliper moves sideways. The noise was present when I drove the wheels while it was jacked. Thanks
Old Jul 24, 2002 | 03:54 PM
Chiovnidca's Avatar
Probably a warped rotor. Could be a loose wheel bearing or a bent hub.
Sorcin
Suspension & Brakes
May 19, 2010 05:16 PM
avio
Apr 16, 2010 12:51 AM
basmasta7
Feb 18, 2010 03:32 PM
B18C-EG
Apr 17, 2008 06:37 PM
ZexyAccord
Sep 28, 2004 06:26 AM
