Tricks to seat chrome rings?
Old Jul 22, 2002 | 06:27 AM
crxfanatic's Avatar
New User
Default Tricks to seat chrome rings?
I'm having a hard time getting my piston rings to seat. Does anybody have any suggestions or tricks to get them to seat?
FYI, motor is d16a6, .020 over, 10.5:1 CR
TIA
Old Jul 23, 2002 | 10:32 AM
kinesistech's Avatar
Default Re: Tricks to seat chrome rings? (crxfanatic)
One of my instructers at school said they had about 2500 miles on an engine with chrome rings, they overrevved it by accident. They thought maybe too high, but the rings were seated and no problems occured. I wouldnt try that though. Hate to blow your ****.
Old Jul 23, 2002 | 02:27 PM
Chiovnidca's Avatar
What oil are you useing?
Old Jul 23, 2002 | 02:55 PM
sgT's Avatar
sgT
Rings should seat instantly.
If they dont seat, either the installation was bad or the honing was bad.
Old Jul 24, 2002 | 04:47 AM
crxfanatic's Avatar
New User
Default Re: Tricks to seat chrome rings? (Chiovnidca)
I used non detergent for the first 1000 then regular Valvoline 10/30 since...
Old Jul 24, 2002 | 12:35 PM
earl's Avatar
Spray some WD 40 down the plug holes. Run the motor. That sometimes will cause more friction on cyl walls to help seat. If that doesn't work, look into a product called Risilone. You add it to your oil to help seat the rings.
If you put new rings on old cylinders, they may never seat right.
Old Jul 24, 2002 | 12:42 PM
Rocket's Avatar
Yeah, non-detergent is good ****.
Old Jul 24, 2002 | 06:23 PM
GruvyTune's Avatar
New User
Default Re: Tricks to seat chrome rings? (earl)
how are you sure they are fully seated? just when the blue smoke stops? that happened pretty fast on my rebuild. does a compression test validate this?
thanks!
Old Jul 24, 2002 | 08:17 PM
earl's Avatar
Default Re: Tricks to seat chrome rings? (GruvyTune)
no smoke...good compression...they're seated
[Modified by earl, 11:54 PM 7/24/2002]
Old Jul 25, 2002 | 03:52 AM
crxfanatic's Avatar
New User
I've got 210 dead nuts across the board for compression. The cylinders were bored and honed when the new pistons and rings went in.
Thanks for the tips guys. I'll try some WD40 or Risilone this weekend, if it doesn't work, the motor comes apart.
Man this is annoying.
Old Jul 25, 2002 | 07:36 AM
earl's Avatar
The good news is that it's just the oil ring that's not seated. If you go the Rislone route, I think you need to give it some time to work. Follow their directions.
Have you jumped on it hard a few times? Usually on about the second dyno pass on a new motor, rings start to seat. Give it a little time before you tear down. I assume you are not getting a huge smoke screen out the exhaust?
Old Jul 25, 2002 | 07:43 AM
crxfanatic's Avatar
New User
Oh, yeah, I have more miles than it should take for them to be seated, and have gotten into it alot since break in time was up.
No big smoke screen on acceleration, but quite a puff if I get on it after coasting down/motor braking.
Old Jul 25, 2002 | 10:04 AM
earl's Avatar
Hhmmmm..valve seals?
Old Jul 25, 2002 | 11:15 AM
crxfanatic's Avatar
New User
Well, I redid the head, with new exhaust valves, and all 16 valve guide seals, 3 angle valve job, shaved .030. I didn't mic the valves in the guides, but they didn't feel out. All my other rebuilds have been fine with this same rebuild.
I swapped this head out for another known good one and I still have the problem.
I appreciate you keeping up with this thread!
Old Jul 25, 2002 | 05:03 PM
earl's Avatar
My rule of thumb has always been if it smokes on acceleration, it's rings...deceleration, valve guides. You seem like you are an experience builder that knows what he is doing. Did you check for any kind of plugged crank case breathers? Something must be sucking or pushing the oil past the rings. If that's not it, maybe an oil ring just failed during installation. There's not too many options left to look at. Let us know if you find the problem.
Old Jul 25, 2002 | 05:18 PM
ITR#132's Avatar
Default Re: Tricks to seat chrome rings? (Rocket)
What is so special about non-detergent?
Old Jul 26, 2002 | 03:18 AM
crxfanatic's Avatar
New User
I'll let you know what the problem was.
Thanks for your time, Earl.
taggart_lumpy
Aug 15, 2008 01:02 PM
V8 BAIT
Jul 14, 2004 03:56 AM
gregv
Mar 3, 2004 05:43 PM
quickergixxer
Sep 22, 2003 11:32 AM
