GSR Obd1 ecu + B20VTEC?
Old Jul 22, 2002 | 07:51 PM
Ri5e's Avatar
Default GSR Obd1 ecu + B20VTEC?
I was wondering if anyone in here is using an OBD1 GSR ECU with a B20VTEC? Any problems ? Running Lean? Sputtering? Thanks.
Old Jul 22, 2002 | 10:32 PM
Kataku2K3's Avatar
Default Re: GSR Obd1 ecu + B20VTEC? (BG Boost)
Well my friends CRVTEC is composed of B20B block, GSR head (Portflow), JE 12.0:1 pistons, stock rods, CTR cams, sprockets, RC 310cc injectors, and a Type R ECU. He still needs a VAFC to richen up his entire band which is perfect at 11% on top end. Oh and yea it runs really lean with the VAFC zeroed out. If you have a turbo then i definately think you'll be wanting more fuel. I would go with a chipped P28 ECU and Hondata stage 4b. That's what my other friend is running on his GSR turbo coupe. Oh and by the way on 22x9.5x13 M&H Racemasters my friends CRVTEC in his 99 hatch with just no back and passenger seat ran 12.8@106. The GSR turbo on 24.5x9x13 MT slicks ran 12.5@112 on 10 psi with full interior. Richen ur **** up with ur turbo and you'll get hella more power!!!!!!
Old Jul 23, 2002 | 04:02 AM
Jeff C's Avatar
Default Re: GSR Obd1 ecu + B20VTEC? (JDMspecEG6)
*scratching head*
BG Boost - the only thing i wonder about is the knock sensor...does your b20vtec have one? plus the motor might need a little more fuel than what the gsr ecu can give.
it might be easier to just get a p28 with a mugen chip, at least i have heard those run the b20vtec pretty good
Old Jul 23, 2002 | 11:59 AM
jcivicsib20's Avatar
I have a crvtec setup running a obd1 gsr ecu. My car lacks top end really bad. I have the fuel regulator set at 45 psi. I dont know what to do. I hooked up a skunk2 chipped p28 ecu and my car detonated like a motha *****. My air fuel gauge was burried rich too. I have only ran my car in the 1/8 mile and its best time was a 9.1 at 77mph. The top end is just not there, somebody please fix my problem!!!!!!!!
Old Jul 23, 2002 | 03:33 PM
tinkerbell's Avatar
Default Re: GSR Obd1 ecu + B20VTEC? (jcivicsib20)
are you running a 2.5in exhaust?
(sorry - this is a stock question for those with B20's complaining about their top end...)
t..
Old Jul 23, 2002 | 10:50 PM
Default Re: GSR Obd1 ecu + B20VTEC? (tinkerbell)
I have a complete apexi dunk exhaust w/ the b pipe
Old Jul 24, 2002 | 06:23 AM
Charlie Moua's Avatar
well i know that ImportBuilders use the P28 chipped Mugen ECU along with hondata tuning. try that.
joemonster
Sep 11, 2009 07:12 AM
biggdogg
Southeast (Sales)
Aug 20, 2008 12:59 AM
JDM*addiction
May 20, 2007 06:42 PM
