How do you correctly clean a Throttle Body
Old Jul 24, 2002 | 12:56 PM
SEVENSIX's Avatar
Default How do you correctly clean a Throttle Body
Just wondering if anyone has the correct procedure.
I had just installed a crankcase breather and moved my CAI to check the TB, I noticed an oily/greasy residue and some mild dirt on the throttle plate. I want to take this out and clean it....
Has anyone done this before?
What chemicals should I use???
Thanks???
Old Jul 24, 2002 | 01:03 PM
JHill's Avatar
Default Re: How do you correctly clean a Throttle Body (SEVENSIX)
The best way is to take it off and wipe it as clean as you can with a old rag, it comes off pretty easy.
You want to avoid using chemical cleaners, because this can eat away at the sealant that manufacturers use on the throttle plate. If you eat away the sealant, then you will probably have eratic idle issues.
Old Jul 24, 2002 | 01:14 PM
SEVENSIX's Avatar
Default Re: How do you correctly clean a Throttle Body (JHill)
cool, thank you!
Old Jul 24, 2002 | 04:16 PM
StyleTEG's Avatar
Throttlebody cleaner should losen any stubborn residue, they make mild cleaners that are safe for coated throttlebodies.
BLKFLSH
Sep 22, 2009 05:49 PM
Civicr2gs5
15
Nov 25, 2004 08:13 PM
speedehatch
Jan 19, 2004 02:28 PM
Al Bundy
Jun 26, 2003 09:56 PM
