HELP! Idle Surging ('93 EG)
Old Jul 21, 2002 | 10:58 AM
LEATHL EG's Avatar
Default HELP! Idle Surging ('93 EG)
Where should I start...
This has been the all time worst and definately most costly problem I have faced in the six years I have owned this car.
The idle is constantly surging between 1500 and 2500. I start the car and it may take five or maybe 15 seconds for it to start, but it has been doing this since before I put her up last winter.
Here is the background on the car:
It's a '93 Civic Coupe DX with a swapped D16Z6. Last year when I was stuck in traffic, I noticed that it was over heating and it managed to get to the point of boiling over and off the top of the temp guage by the time I could reach a spot on the highway to pull over. The radiator was toasted and the fan for what ever reason was not kicking on when the temp would get high.
After this happened I decided to put in a GSR radiator and a FAL fan to avoid any further cooling issues. The day that I did this my car began it's trip down idle surging lane. I initially thought that it was air in the cooling system and I bled it like ten times and couldn't get all of the air out. So, I took it in to the dealership and had them do a professional coolant flush. They told me that they couldn't pressurize the cooling system and that I had a blown head gasket. Great!
Since then I had the head checked and it wasn't cracked so I had a valve job and the head milled. I replaced all of the gaskets with a head set. This was not the problem. I have checked cam timing, it is absolutely perfect, and there is no chance of air getting into the cooling system from the head.
This is what I have replaced or bought since then:
ProFlo Throttle body (59mm)
TPS
MAP Sensor
O2 Sensor
Distributor, Cap, and Rotor
MSD SCI Ignition, Plug Wires, Coil
Timing belt
Alternator, and belt
Battery
Colored Hose kit (hoping to eliminate a vacum leak)
The error codes we keep getting when we short the ECU are seven and three. Someone told me that those are the TPS and MAP. Which I have already replaced. Is this right? I don't have a place to check error code numbers. One time we got a fourteen, but that was after we switched around the wiring harnesses for the TPS and MAP.
I have taken it to like five different mechanics and no one tell me anything. They all wind up blaming it on this extra wiring harness that is hanging off of the firewall next to the TPS. It is just and extra harness that was left over from the 1.5 that was in there before the swap. Just to clarify the swap ran fine for two years before this all went down.
I have no idea what else to do and I have already spent like $900 dollars in the last two weeks alone. If some one could give me any help I would seriously be in debt to them for the rest of my life.
Thanks,
Kyle
Old Jul 25, 2002 | 08:27 PM
Custom ATx's Avatar
Default Re: HELP! Idle Surging (LEATHL EG)
Sorry, I didnt read all your post, just the title... but this may help
https://honda-tech.com/zerothread?id=135165
Old Jul 26, 2002 | 04:14 AM
LEATHL EG's Avatar
Default Re: HELP! Idle Surging (Custom ATx)
Thanks for your post. That was a really helpful thread. I just figured out that it was the IAC. Something I had over looked in all of the confusion. I can't say enough how helpful everyone has been here. I had another thread going about the same thing. (of course I later found out that was not highly regarded and I won't do that again) Each person that has replied has had more helpful info than the tools working at the dealership. (TOOLS!!!)
Dealeships suck!
Old Jul 26, 2002 | 09:31 AM
Custom ATx's Avatar
your welcome
ed_hdz
Apr 8, 2012 06:30 AM
the.hamburglar
Apr 22, 2007 11:20 AM
blakacintegra
Dec 5, 2006 07:46 PM
rusted_eyes
23
Jun 3, 2004 08:36 PM
LEATHL EG
10
Jul 23, 2002 04:29 AM
