half shaft/intermediate shaft
Old Jul 22, 2002 | 10:03 AM
GruvyTune's Avatar
New User
Default half shaft/intermediate shaft
drivers side.
pulled my cv joint out of socket by mistake. cant get back in with boot on.
apparently once the joint separates, the ball rollers collapse and you have to take it all apart, I just went and got a half shaft for$69.
Is it hard to remove and reattach the half shaft to the intermediate shaft?? the manual shows some kind of bearing that needs to be pulled and pressed in??
thanks
Old Jul 22, 2002 | 10:14 AM
sgT's Avatar
sgT
Default Re: half shaft/intermediate shaft (GruvyTune)
you just push it on. a little force may be necessary.
NEVER pull on an axle or hit it with a hammer to get it ON.
To get the driver side off you should take a BFH and hit the inboard "cup" to
knock it off.
Old Jul 22, 2002 | 10:48 AM
GruvyTune's Avatar
New User
Default Re: half shaft/intermediate shaft (sgT)
really? the outer shaft just pushes onto the inner shaft?
Old Jul 22, 2002 | 10:51 AM
sgT's Avatar
sgT
yes, its held in place by a retaining clip.
Old Jul 22, 2002 | 12:34 PM
92sleepR's Avatar
New User
I have two, 18" long pieces of 1x2 oak that i use to lever the thing on. That joint is ALWAYS a bitch for me. I basically use one on each side of the inner joint to provide an even pressure across the rubber boot. you don't want to tear the boot getting it on, it will squirt CV grease all over your engine bay if you do. (do you wonder how I know this )
Mike
B_Swapped93
Oct 28, 2013 01:38 AM
MadVladCivic
Jan 22, 2013 12:02 PM
MeanGreenEG9
Mar 17, 2003 06:24 PM
mickey513
Feb 5, 2003 06:14 AM
