Need help quickly Question Concering Suspension
Old Jul 24, 2002 | 09:39 AM
95c1v1cs1's Avatar
Default Need help quickly Question Concering Suspension
My friend has a 98 Acura Integra LS and I was wondering if i can disconnect this line. I'm pretty sure that it is ABS, but i don't know how to disconnect it, if you should disconnect it. I need to get the LCA off, but first i need this line disconnected. Can I disconnect it? And if so, what do i need to do?? Thanks alot guys, i appreciate it!
Old Jul 24, 2002 | 09:41 AM
reefer_bob's Avatar
Default Re: Need help quickly Question Concering Suspension (95c1v1cs1)
You shouldn't have to disconnect that to get the LCA off... it'll strech. I've taken LCA's off with out disconnecting that line. Take the brackets off that hold it, and give yourself a little more slack...
Old Jul 24, 2002 | 10:14 AM
95c1v1cs1's Avatar
Default Re: Need help quickly Question Concering Suspension (reefer_bob)
Well, We can't get enough room to take the springs off, because the bolt to the strut is frozen solid, as you can see from the pic we even tried to drill thru it ..... So how would we take it off? And what line is it??
[Modified by 95c1v1cs1, 7:15 PM 7/24/2002]
Old Jul 24, 2002 | 03:33 PM
Chiovnidca's Avatar
That's your ABS wheel speed sensor. remove the two bolts that hold it to the knuckle and move it out of the way.
Old Jul 24, 2002 | 03:39 PM
reefer_bob's Avatar
Hmmm... not so good. I'm supprised you drilled the head when the bolt still had shoulders left on it. Let me refer you to a another thread in the Integra Forum...
https://honda-tech.com/zerothread?id=235638
pinkspider
May 26, 2007 10:30 AM
JDM CTR EK
Apr 29, 2004 06:37 PM
crooked muffler
May 22, 2003 07:34 PM
