Now it's a CEL code 5! help!
Old Jul 24, 2002 | 05:57 AM
NawTeeCRX's Avatar
Default Now it's a CEL code 5! help!
My problem was originally posted as cel code 15 but now it's a 5.
I replaced a connector for the positive wire coming from the ignitor and taped up a couple of the wires since they were frayed. I put it all back together, reset the ecu, and the same problem was happening.
It was still cold-idling at 1,000 really roughly like it was misfiring then shot up to 2,500rpm then died.
BUT this time instead of 15 the CEL code was 5 which is MAP sensor. WTF?!?! This car is driving me nuts.
Any ideas?
Here's my setup:
'89 CRX dx
'99 d16y8 vtec motor
'89 Integra ecu
Field's vtec controller
Old Jul 24, 2002 | 07:27 AM
KornyCivic's Avatar
Default Re: Now it's a CEL code 5! help! (NawTeeCRX)
I had a similar problem (the idle RPM jumping around) when I did my B16A1 swap, but I wasn't getting engine codes...it turned out we didn't have the vaccume plugged up correctly (the B16a1 has some extra vaccume lines and stuff that you don't need when you put it in a 95 ex) but we got those plugged off correctly and everything worked fine.
Old Jul 26, 2002 | 07:38 AM
NawTeeCRX's Avatar
Default Re: Now it's a CEL code 5! help! (KornyCivic)
It was a torn vacuum line! Thanks for the suggestion.
skaternak
12
Aug 13, 2009 08:39 PM
japanationcivic
12
Nov 16, 2008 02:59 PM
NawTeeCRX
Jul 26, 2002 07:43 AM
NawTeeCRX
Jul 24, 2002 05:52 AM
NawTeeCRX
Jul 22, 2002 01:14 PM
