backfiring??
Old Jul 21, 2002 | 03:30 AM
aeolus's Avatar
Default backfiring??
My h22a will backfire sometimes when i shift.No cell codes.i checked the plugs,and they look fine,no excessive back soot on them,they look grey in color,im running type s pistons with a milled head.any ideas??possibly lean backfire??
Old Jul 21, 2002 | 08:05 AM
advanracing62's Avatar
Default Re: backfiring?? (aeolus)
normally, a backfire is due to too much fuel entering the chamber. I would have to think that there is a spot in your RPM range where the fuel is a little rich and when you down shift it causes the fuel to "pool" in the chamber, your tip in fuel comes in and mixes with that causing a rich condition which then creates a back fire when it exits into the exhaust.
I know run-on sentence...
Old Jul 21, 2002 | 10:22 AM
solo-x's Avatar
Default Re: backfiring?? (advanracing62)
not a worry, most cars have a mild backfire due to the rapid opening and closing of the tb. the higher output your motor has, and thus higher fuel demands, will increase the likelihood of a "pop" coming from the exhaust. keep building the motor and soon you'll shoot a small flame out when you shift.
basilwatts
Honda Ruckus and Scooters
Dec 12, 2017 08:26 PM
street_ride14
Apr 22, 2015 01:47 PM
PINKS
Mar 19, 2007 12:07 PM
D@nnY
Jan 11, 2004 07:57 AM
