Done installing new engine, problems (pics)
Old Jul 22, 2002 | 12:54 AM
legendboy's Avatar
Default Done installing new engine, problems (pics)
Ok, I've installed a 98 B18b in my 94 teg. Car runs, kinda. It has no power, sounds like rattling over 20% throttle, smells funny, stalls without gas, no cel, heat is ok, engine sounds funny under acceleration, I'm not sure exactly what I need to do to tune it but I couldn't find the PCV on this OBD2 engine. My old engine had it becide the oil filter. Now the hose is pluged. Help on this one. What the hell is this hole? The PCV??? I couldnt set the timing cause the light would not work so I still need to do that but even if I rotated the distrib it made to difference.
Thanks guys.
here is the new motor
Old Jul 22, 2002 | 03:25 AM
rolow's Avatar
Default Re: Done installing new engine, problems (legendboy)
The hole is for the PCV.
Old Jul 22, 2002 | 07:05 AM
legendboy's Avatar
Default Re: Done installing new engine, problems (rolow)
So do I still need the little black box that was attached to the block of my old engine?
So becides the timing, what else do I need to tune up? I put a new crank pully on, new cam gears, new timing belt as well as had the whole head apart and cleaned up.
Old Jul 22, 2002 | 08:34 AM
Sleeper's Avatar
No you don't need the box. They do not come on 96+ B18B's, or 97+ B20's. They have the PCV valve in the valve cover, no box.
Old Jul 22, 2002 | 08:36 AM
nixadm's Avatar
Default Re: Done installing new engine, problems (Sleeper)
sleeper is right...
Old Jul 22, 2002 | 08:37 AM
legendboy's Avatar
pcv ok, can someone explain to me how to properly set the timing when the whole engine has been apart?
Old Jul 22, 2002 | 08:49 AM
Sleeper's Avatar
Ignition timing? Warm to operating temp, short service connector, adjust via distributor.
Old Jul 22, 2002 | 09:32 AM
legendboy's Avatar
Old Jul 22, 2002 | 09:53 AM
b18b98's Avatar
make sure you using the right ECU and double check all vac lines and sensors
dko30133
Honda Civic (2001 - 2005)
Oct 16, 2017 07:24 PM
lukewarm
Honda CR-V & Element
Mar 16, 2013 12:20 PM
Spensersdad
Aug 14, 2012 05:54 PM
adamc11
Mar 27, 2011 11:52 PM
rewhipple
11
Nov 15, 2006 01:04 PM
