Death by water - what to do now?
Old Jul 21, 2002 | 01:11 PM
GSRlove's Avatar
Default Death by water - what to do now?
About a month ago, I drove through the equivalent of a lake. The engine froze & wouldn't turn over. I just today pulled the head today to reveal the ugliness that you see before you. This is my first endeavor of this nature & I'm not sure where to start. What am I going to have to do? I'm guessing that I can just hone the cylinders to smooth them out again, get new rings & that may be all. It looks to me like the pistons are okay. Am I correct or will I need to bore the cylinders necessitating new pistons also? Is there likely bearing and/or rod damage? I suppose that the answers to my questions may be circumstancial, but any experienced input would be greatly appreciated.
http://www.imagestation.com/album/?i...53137597&idx=1
[Modified by GSRlove, 11:31 PM 7/21/2002]
Old Jul 21, 2002 | 01:26 PM
GSRlove's Avatar
Default Re: Death by water - what to do now? (Teken)
How do I get the pic on here?
[img] E:\Program Files\Polaroid\PhotoMAX 3.0[/img]
Old Jul 21, 2002 | 01:54 PM
Kamin's Avatar
Default Re: Death by water - what to do now? (GSRlove)
you have to upload it to the internet
Old Jul 21, 2002 | 02:26 PM
GSRlove's Avatar
Default Re: Death by water - what to do now? (KAMiN)
That's better - thanks. How can I get the image into the message?
Old Jul 21, 2002 | 02:34 PM
GSRlove's Avatar
No holes, just a bunch of surface rust.
Old Jul 21, 2002 | 02:49 PM
GSRlove's Avatar
Will I not need new rings? Can't I just hone the cylinders?
Old Jul 21, 2002 | 04:46 PM
Westrock2000's Avatar
Thats a crazy weld job on the header
Old Jul 21, 2002 | 05:03 PM
GSRlove's Avatar
Default Re: Death by water - what to do now? (Westrock2000)
You should see the custom collector that I made. Can you tell that I taught myself to weld using this header?
Old Jul 21, 2002 | 07:32 PM
IN VTEC's Avatar
Check the bore diameter for size and out-of-roundness using a cylinder bore dial gauge, or have the machine shop do it.
Chances are, the machine shop will hone it first just to get a clean surface and then remeasure to check for the necessity of overboring. The biggest concern is that the bores are scratched too deeply to be fixed with a simple bore hone.
I'd also worry about the wrist pins, rod bearings, mainshaft bearings, the crank and rod journals. Measure everything for out-of-spec tolerances, and replace what you need. Lot of work, but you can never be too safe when something like this happens. Service Manual will tell you exactly how to do all this stuff, and the tools/gauges you need.
Regardless, follow standard rebuild replacement procedure and replace the following:
.mainshaft bearings
.rod bearings
.piston rings
.seals & gaskets
.valve seals
Old Jul 21, 2002 | 09:13 PM
B19CivicHB's Avatar
Default Re: Death by water - what to do now? (IN VTEC)
Pic for ya'll
Old Jul 21, 2002 | 09:42 PM
Kamin's Avatar
Default Re: Death by water - what to do now? (B19CivicHB)
if your gonna do it, do it right. save the extra money and build the sob.
its already apart anyway.
Old Jul 21, 2002 | 09:58 PM
JHill's Avatar
You broke the rod in #1 for sure. The other components may be ok, but you will need to check them to be sure. Usually only one cylinder will sustain damage from a hydrolock, the one in the compression stroke.
Old Jul 21, 2002 | 10:02 PM
samiam's Avatar
# 1 and 4 is a dead giveaway.. pull the oil pan and see if the rods are broken.
[Modified by samiam, 11:03 PM 7/21/2002]
Old Jul 22, 2002 | 05:40 AM
IN VTEC's Avatar
Default Re: Death by water - what to do now? (samiam)
You're right. Didn't pick up on it before. Cylinders 1 and 4 should both be at TDC. #1 is at MDC.
[Modified by IN VTEC, 8:41 AM 7/22/2002]
Old Jul 22, 2002 | 12:19 PM
B19CivicHB's Avatar
Default Re: Death by water - what to do now? (C5_ALLMOTOR)
who in the blue hell welded your header Stevie Wonder
Function over fashion at its best
Old Jul 22, 2002 | 12:26 PM
92sleepR's Avatar
New User
Judging by the position of piston #4 relative to where it SHOULD be you have a majorly fucked up con-rod. I would be concerned about damage to the bearings or crank. At a minumum you should replace that piston, rod, bearings, and hone that cylinder. Actually, while your in there you should probably hone all the cylinders and put better pistons (high comp) in.
BTW, who the hell welded up your header That thing looks nasty.
Mike
Old Jul 22, 2002 | 02:05 PM
reefer_bob's Avatar
Default Re: Death by water - what to do now? (92sleepR)
I wouldn't even mess with it. I'd bore the whole thing, the minimum you can get away with (.5mm?).
New Pistons (wrings, wrist pins, etc.)
New Rods
ALL new bearings
Check your crank for bends, cracks.
Check the deck of the block for any warpage
Check the head for warpage
Check the crank journals and bearing caps for being out of round.
I'm sure I'm forgetting something...
Old Jul 22, 2002 | 03:16 PM
CivicEK.PDX's Avatar
Default Re: Death by water - what to do now? (reefer_bob)
Ya...hes right...either your crank or rod is FUCKED
Old Jul 22, 2002 | 03:28 PM
GSRlove's Avatar
Default Re: Death by water - what to do now? (CivicEK.PDX)
I know, I know, the weld job is as shitty as a port-a-john. Hell, y'all should see the custom collector that I made - talk about some fucked-up welding! The problem is that I taught myself to weld on this header & originally, used normal wire with no gas! Yeah, I know, I'm a dick-bag. But hey, when it was all said & done, that ******* header made power kick in like boost, (LITERALLY), @ around 5100rpm. God I miss driving this car!
Old Jul 22, 2002 | 05:30 PM
JV's Avatar
JV
Who?
Props for doing it yourself...
Although it does look bad...
Old Jul 22, 2002 | 08:14 PM
PisFacedSlappR_returns's Avatar
Default Re: Death by water - what to do now? (JV)
Holy **** thats a ******* rust bucket.hahahahahahah that sucks *** man.
beboo
Nov 24, 2009 06:38 AM
teg92
Jul 27, 2004 03:45 PM
baphomet
Jan 19, 2004 06:07 PM
94gsr4d
Jan 29, 2002 08:37 PM
