not changing the washer on the oil drain bolt?
Old Jul 22, 2002 | 01:00 PM
quikrpm'z's Avatar
Default not changing the washer on the oil drain bolt?
will this always cause a leak? IF so why, i cant see how it creates a seal.
Old Jul 22, 2002 | 01:08 PM
Mikey3000's Avatar
Default Re: not changing the washer on the oil drain bolt? (quikrpm'z)
if you don't have one on there it'll leak, at least mine did. you can just keep reusing the same one and it shouldn't leak. the owners manual just wants you to spend more money.
Old Jul 22, 2002 | 01:37 PM
quikrpm'z's Avatar
Default Re: not changing the washer on the oil drain bolt? (Salvatore Leone)
i reused the one that was on there previously, and its leaking.
Old Jul 22, 2002 | 01:42 PM
quikrpm'z's Avatar
Default Re: not changing the washer on the oil drain bolt? (Teken)
That is because it is a *crush* washer and deforms to match the grooves of the oil pan... You may reuse it maybe once, assuming the proper amount of torque is not applied...
But if it was, then 9x out of 10, it will leak as you have discovored...
Teken
dang, what would u do teken? i dont feel like changing the oil again, and i dont want to over tighten the bolt.
Old Jul 22, 2002 | 01:47 PM
quikrpm'z's Avatar
good stuff as always.
Old Jul 22, 2002 | 01:53 PM
reefer_bob's Avatar
Agreed. I re-use the washer once. I just flip it over.
If you have a cool parts counter, you just say, "hey, could you throw a couple washers in the bag for me too?" and usually they will. I do that everytime I buy parts at either the Acura or Honda dealership, and I have prolly 20-30 washers now...
Old Jul 22, 2002 | 02:20 PM
TypeSH's Avatar
Default Re: not changing the washer on the oil drain bolt? (reefer_bob)
depends on the washer you use. A rubber one I'd think could be reused, but a cardboard one shouldnt be reused too many times.
Old Jul 22, 2002 | 02:32 PM
speedymon's Avatar
Default Re: not changing the washer on the oil drain bolt? (TypeSH)
Whoa...i don't even use a washer.
Old Jul 22, 2002 | 03:16 PM
PyR01-0347's Avatar
What about the Spoon Oil Drain Plug? It came with a metal washer, do I need to replace it?
Old Jul 22, 2002 | 06:10 PM
Power1Pete's Avatar
Default Re: not changing the washer on the oil drain bolt? (PyR01-0347)
yes, it is identical to the honda OEM CRUSH washer. plus it is dirt cheap (< $0.25 each)
Old Jul 22, 2002 | 06:26 PM
BreakStuff's Avatar
New User
Default Re: not changing the washer on the oil drain bolt? (speedymon)
Hey.. neither does the Jiffy-Team Quick Lube guys!
Old Jul 22, 2002 | 07:50 PM
MattG's Avatar
New User
Change the washer!. In the long run its cheaper. As some have discovered an old washer will leak. Most people just tighten the bolt more to stop the leak. Eventually the threads will strip in the pan. All my local honda filters come with a new washer pre-packaged with the filter. Kinda makes it a no brainer.
Old Jul 24, 2002 | 09:45 AM
PandaBear's Avatar
Hey, do not flip the washer over and reuse it.
The soft side of the washer is suppose to be pushed and compressed to fit the curve of the drain hole for a perfect fit, that is why you are suggested to replace it. Flipping it over and use it is having the hard side rub against the pan, it is worse than reusing it on the same side (which should be no problem if you torque it equal to or slightly higher than your last usage, but don't push it too far or your thread on the drain plug will be damaged).
Old Jul 24, 2002 | 09:47 AM
reefer_bob's Avatar
Default Re: not changing the washer on the oil drain bolt? (PandaBear)
The washer doesn't have a hard side / soft side. It's just a generic aluminum washer...
Old Jul 24, 2002 | 10:03 AM
brcivic411's Avatar
just buy more washers... they're so cheap
Old Jul 24, 2002 | 10:34 AM
quikrpm'z's Avatar
update: i just retightened the bolt, i actually could get about an 1/8 turn from it. I guess the heat of the oil and lack of a new washer really loosens it up a bit.
i also went ahead and bought some filters and washers from the dealer. They charged me 40 cents per washer .
Old Jul 24, 2002 | 05:09 PM
type r 01-1063's Avatar
Teken: WTF???
DEALER SUCKS MONKEY ***** FOR RAPING A GUY FOR A FRICKEN WASHER !!!
Cerritos Acura charged me too but I don't remember how much. That has pretty much discouraged me from buying washers.
Old Jul 25, 2002 | 12:09 PM
WOTTEG's Avatar
They are less than 5 cents at my honda dealer. I bought 20 of them for like $1.08.
I "lube" both sides of the washer too when putting it on. Kind-of like wetting the rubber gasket on an oil filter.
Also an FYI: make a point to check the base of the dipstick tube for leaks when you check your oil. Two people on this board have had engine failure from an unnoticed leak at this area. Honda should offer to fix it under warranty.
Old Jul 25, 2002 | 12:21 PM
SEVENSIX's Avatar
Default Re: not changing the washer on the oil drain bolt? (WOTTEG)
I cant remember when I had a washer on the Oil bolt. Ive checked it many times... no leaks...
Old Jul 26, 2002 | 05:40 AM
jweller's Avatar
Default Re: not changing the washer on the oil drain bolt? (SEVENSIX)
the parts counter where I buy filters always just tapes a new washer onto the top of the filter when I buy them. I know they charge me for them, but it isn't too much. even if its .50, i think the peace of mind is worth it.
Old Jul 26, 2002 | 05:59 AM
92sleepR's Avatar
New User
Get a new aluminum crush washer from like Track Auto or somewhere. They are only a few bucks. Even I am not that cheap
Mike
Old Jul 26, 2002 | 09:50 AM
Power1Pete's Avatar
sounds like the o-ring on the dipstick pipe failed. i changed mine when i had my timing belt done. the o-ring itself costs next to nothing, but the labor is a killer.
Old Jul 26, 2002 | 11:14 AM
BROOD's Avatar
I've had good luck with reusing the AL crush washer two-three times and after wards replacing it with a new one. No leaks yet.
kingdeadguy
Feb 29, 2012 04:39 PM
boostmee
Aug 18, 2008 02:05 PM
teewhy55
13
Dec 13, 2004 11:17 AM
eg crunkmonster
Feb 3, 2004 08:47 PM
