how did the distributor mess up?
Old Jul 23, 2002 | 07:33 PM
LB CRX's Avatar
Default how did the distributor mess up?
to make a long story short, my timing belt jumped teeth and my valves bent. i got the head worked on and the car didnt start. i figured out that the distributor was out too. my question is, what messed up what?
Did a faulty distributor cause the timing to skip, or did the jumped timing cause the distributor to break? TIA
Old Jul 24, 2002 | 03:40 AM
88_SC_CRX_Si's Avatar
New User
Default Re: how did the distributor mess up? (LB CRX)
My guess is dist bearing was starting to seize-up, causing the belt to jump...
Old Jul 24, 2002 | 07:52 AM
kyler's Avatar
distributor might've loosened up, kicked out at an angle binding hard on the cam and therefore making the belt jump...
my guess at least..
Old Jul 24, 2002 | 08:14 AM
92sleepR's Avatar
New User
Default Re: how did the distributor mess up? (88_SC_CRX_Si)
If a distributor base bearing siezed the heat it generated probably fried the sensors. check the bearings and if they are bad the easiest thing to do is just replace the distributor.
Mike
taguchi09
Jun 11, 2011 04:52 PM
96a-ccord
Feb 26, 2010 02:04 PM
strategy400
Aug 11, 2008 03:49 PM
acclude435
Dec 3, 2004 03:31 PM
steve_s
Jul 2, 2003 08:36 PM
