Is this true or something that will create problems...
Old Jul 22, 2002 | 09:01 AM
kay_animation's Avatar
Default Is this true or something that will create problems...
This is for sale on an ebay auction and i'm about to replace my O2 sensor and headers and was wondering if I should buy this and use it as well. Is this a good mod upgrade or will this destroy my engine?
This Is what the saler typed:
YOU ARE BIDDING ON A ELECTRICAL DEVICE TO REPROGRAM YOUR OXYGEN SENSOR TO GET THE "PERFECT MIXTURE OF FUEL AND OXYGEN SO YOUR CAR WILL RUN AT IT'S PEAK LEVEL. HERE IS WHAT IT WILL DO: Every new car, and most cars produced after 1980, have an oxygen sensor. The sensor is part of the emission control system and feeds data to the Engine management computer. The goal of the sensor is to help the engine to run as efficiently as possible and also to produce as few emissions as possible. A gasoline engine burns gasoline in the presence of oxygen. It turns out that there is a particular ratio of air and gasoline that is "perfect", and that ratio is 14.7:1 A stock cars ratio is 16.7:1 This device will make your car have the "perfect" ratio therefore it will maximize and boost the performance of your car. If there is less air than this perfect ratio, then there will be fuel left over after combustion. This is called a rich mixture. Rich mixtures are bad because the unburned fuel creates pollution and it will slow your car down. If there is more air, then there is excess oxygen. This is called a lean mixture. A lean mixture tends to produce more nitrogen oxide pollutants, and in some cases it can cause poor performance and even engine damage. The oxygen sensor is positioned in the exhaust pipe and can detect rich and lean mixtures. You are bidding on a device that plugs in to the wiring HARNESS under the hood that controls part of the oxygen sensor. The mechanism in most sensors involves a chemical reaction that generates a voltage. The engine's computer looks at the voltage to determine if the mixture is rich or lean, and adjusts the amount of fuel entering the engine accordingly. The reason why the engine needs the oxygen sensor is because the amount of oxygen that the engine can pull in depends on all sorts of things like the altitude, the temperature of the air, the temperature of the engine, the barometric pressure, the load on the engine, etc. When the oxygen sensor fails, the computer can no longer sense the air/fuel ratio, so it ends up guessing. Your car performs poorly and uses more fuel than it needs to. Shipping and Handling is free! I accept paypal, MO, and personal checks. Please send all paypal payments to charityhodge@hotmail.com. Please check out my other auctions for more horsepower gain. Email me at charityhodge@hotmail.com with any questions
Or you can see the auction here:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1845599189
Old Jul 22, 2002 | 09:12 AM
Default Re: Is this true or something that will create problems... (kay_animation)
ay, that's ok, somebody showed me the light about the ripoff electrical pieces. Thanx EE_Chris!
You administrators can delete this post
Sorry about the dumb question...
imzjustplayin
Oct 11, 2011 08:25 PM
JDM_SOHC
12
Mar 28, 2009 02:52 PM
007EG
Nov 29, 2007 09:57 AM
Zimmerman
Aug 5, 2006 12:17 PM
BlackGSR87
Mar 7, 2003 08:45 AM
