knock sensor engine code what to do???????
Old Jul 22, 2002 | 11:25 PM
speshuled619's Avatar
Default knock sensor engine code what to do???????
just finished dropping in a obd 1 gsr motor into an eg and everything went fine until the car threw up a 23 engine code which i believe is knock senor. please let me know how and what i need to fix this problem. its the only code that its throwing up. im gonna be taking this to the ca. state ref to get the swap legalized.
Old Jul 22, 2002 | 11:28 PM
Stryker908's Avatar
Default Re: knock sensor engine code what to do??????? (speshuled619)
Wire up the knock sensor ... D3 is the pin position ... or get a rechiped ecu that dosent look for a knock sensor
Old Jul 22, 2002 | 11:34 PM
Default Re: knock sensor engine code what to do??????? (JDM_SIR_II)
i was wondering if you have a pic of that d3? also where is the knock sensor located? please elaborate ive never done this or had trouble with this. thanks for your help
Old Jul 22, 2002 | 11:39 PM
kinesistech's Avatar
The knock sensor is on the back of the block, above and left of the oil filter. It has a one wire plug. Its above the water pipe, the one below it is oil pressure sensor.
Old Jul 23, 2002 | 11:50 AM
Default Re: knock sensor engine code what to do??????? (kinesistech)
where on the ecu or harness to i connect the wire? whats the color of the wire?
Old Jul 23, 2002 | 01:27 PM
Mikey3000's Avatar
you need to pull out the wire (along with the metal clip) from A20 and put it in D3.
Old Jul 23, 2002 | 08:53 PM
Default Re: knock sensor engine code what to do??????? (Salvatore Leone)
where do i go about finding out where this a20 and d3 slots are? thanks for everyones input
Old Jul 24, 2002 | 04:30 AM
Mikey3000's Avatar
go to your ecu. unplug the 3 harnesses that plug into the ecu. the big one (26 pin) is A. the middle one is B (14 pin) and the last one is D (22 pin). so A20 is on the bottom row (looking at wire side of harness, not empty side). count even #'s on the bottom row (2, 4, 6, 8....) until you get to 20.
D3 would be the 2nd pin # on the top row of the 3rd connector (again looking at the wire side). that space should be empty.
Old Jul 25, 2002 | 10:30 AM
actually that space is is not empty? so what do you think i should do?
Old Jul 25, 2002 | 10:32 AM
also there are wires in the slots A20 and D3. so im confused now.
Old Jul 25, 2002 | 01:27 PM
Mikey3000's Avatar
there should be a wire in A20, there shouldn't be in D3. what model civic do you have?
Old Jul 25, 2002 | 04:28 PM
i have a 95 si hatch
Old Jul 25, 2002 | 05:12 PM
Mikey3000's Avatar
oh that may be different than my CX because i believe those come with a knock sensor. my CX didn't. start a new thread or something and ask these bastards how to do this on an Si. sorry i couldn't help.
ek4 sir civic
Jun 23, 2007 06:02 PM
civiconfire
Sep 10, 2006 07:31 PM
EF_LSVtec
Apr 10, 2003 11:25 AM
speshuled619
Jul 26, 2002 10:23 AM
speshuled619
Jul 26, 2002 05:18 AM
