disabled vss
Old Jul 21, 2002 | 08:49 PM
r7's Avatar
r7
Default disabled vss
how do i eliminate the need for a vehicle speed sensor? or make it work with an 88 crx si? (b16a motor , y1 tranny, pr3)
Old Jul 21, 2002 | 09:41 PM
JHill's Avatar
Default Re: disabled vss (r7)
You will need to get a modified ECU, or in a pinch, pull the VSS input pin to the ECU. But then your Vtec won't come on, so you need to pull the pin to that too.
You could then get a 3 step control module for a MSD 6AL and run Vtec off of that, or like I did, wire Vtec to run all the time. Idle is kind of lumpy, but that is not what I was concerned about, I didn't want to waste $200 of track time without Vtec and limited to 112mph. Without the VSS, my rex was at 135 into turn one at Pacific Raceways (Seattle), talk about fun.
I wouldn't recommend full time Vtec for everyday use.
Old Jul 21, 2002 | 10:39 PM
tinkerbell's Avatar
Default Re: disabled vss (JHill)
what gearbox is that with?
t..
Old Jul 21, 2002 | 11:10 PM
JHill's Avatar
Default Re: disabled vss (tinkerbell)
That was with the YS1 4.40 FD at 7500 RPM in 5th .87
Old Jul 22, 2002 | 07:21 AM
r7's Avatar
r7
so, what do people normally do? for the b16 swap into crx
Old Jul 22, 2002 | 07:49 AM
AussieK24's Avatar
I run a Autometer Shift Light module to operate VTEC. I tried to wire up the VSS but without success. I like it the way I have it now. Adjustable via pills OR switching to 6 or 8 cylinder.
Old Jul 22, 2002 | 07:54 AM
ricodemus's Avatar
you can use your vss from your d series tranny. yes, it's cable operated but the ecu gets the signal from the gauge cluster. If you want to use the electronic vss, you will need the EF SiR cluster. I bought all that crap, but I am still running the cable vss with the si cluster.
Old Jul 22, 2002 | 10:37 PM
r7's Avatar
r7
Default Re: disabled vss (ricodemus)
so i CAN use the cable way? ok, than why am i getting a code 17 ? =P
maybe cable not in all the way?
Old Jul 22, 2002 | 10:49 PM
tinkerbell's Avatar
does hte speedo work? if so cable is in all the way!!!
Code 17 would then mean that it is a problem with the connection between the gauge/cluster???
i used the mechanical VSS out of my 83 Lude with the PR3 ECU OK but i HAD to use a cluster that matched the ECU!!!
or the VSS of your original CRX cluster needs to be hooked upto "B16" (middle connector) on the PR3 ECU
does this help you???
t..
Old Jul 23, 2002 | 07:15 AM
r7's Avatar
r7
the speedo works, i'll check if it's in all the way, if not, how does it stay in?
ill check the connection, i think it's the position as the si computer, b16 wire
Old Jul 24, 2002 | 04:54 PM
r7's Avatar
r7
anyone?
civicseth
16
May 18, 2005 08:51 PM
93FastLs
Mar 25, 2005 12:24 PM
veilsides2000
Oct 18, 2004 07:38 AM
dash8264
13
Feb 9, 2004 02:02 PM
c8r9x
Aug 17, 2003 12:50 AM
