Valve adjustment and power
Old Jul 23, 2002 | 09:08 AM
Mover's Avatar
Default Valve adjustment and power
I've adjusted my valves a few times but haven't experimented.
I've come across two schools of thought on this.
Tight clearance = good top end power (more lift/duration)
vs.
Tight clearance = good low end power
Any thoughts ?
Old Jul 23, 2002 | 09:20 AM
2point6's Avatar
Default Re: Valve adjustment and power (Mover)
I personally set the intakes to the tight side of spec (.006-.007, so .006) and the exaust I adjust to the loose side (.007-.008, so .008). The intakes valves don't get as hot as the exaust valves, so the looser adjustment on the exaust allows the valve to be closed for slightly longer (albiet, milliseconds) and this helps to dissipate heat from the valve to the seat.
[Modified by 2point6, 6:21 PM 7/23/2002]
Old Jul 26, 2002 | 10:35 AM
Mover's Avatar
Default Re: Valve adjustment and power (2point6)
Anyone else ?
Old Jul 26, 2002 | 11:32 AM
IlikeTODA's Avatar
I've never heard anything about making more power. I just adjust mine on the tighter end so they don't rattle or make noise.
Thanks, J
Old Jul 26, 2002 | 02:53 PM
Mista Bone's Avatar
D Tranny Guru
tighter (.004I/.005E) extends the power band.
Mine went from 6800 to 7100 rpm on a Z6.
99black_em1
43
Mar 3, 2009 09:27 PM
petergriffen
Jul 19, 2006 07:27 PM
Ch3mik
Jun 4, 2005 08:13 PM
magic hat #9
Aug 2, 2003 10:31 AM
