? ? ? Sway bar considerations ? ? ?
Old Jul 22, 2002 | 06:43 AM
osbornsm's Avatar
New User
Default ? ? ? Sway bar considerations ? ? ?
What is a good sway bar for a 99-00 Civic Si. What is an improvement over the stock setup? Looking at the Comptech Sway/Tie combo. I want a little oversteer but don't want to drift thru every turn. What is recommended for a hack driver such as myself that needs to learn how to drive for real. I.E. not lifting off gas in turns or sudden steering jerks. What you think?
Later 8
Old Jul 22, 2002 | 06:44 PM
Power1Pete's Avatar
Default Re: ? ? ? Sway bar considerations ? ? ? (osbornsm)
try the autocross forum. good luck.
Old Jul 22, 2002 | 06:58 PM
IM ALL BOB's Avatar
Default Re: ? ? ? Sway bar considerations ? ? ? (Power1Pete)
check beaks products.. they offer the ITR 22 mm Rear sway bar with tehre reinforcement kit at a reasonble price. http://www.beaksproducts.com/ek-quickswap.html
good luck
Old Jul 22, 2002 | 07:54 PM
MattG's Avatar
New User
Swaybar is the best bang for your buck if the car is stock. It reduces understeer very dramatically. I have the comptech swaybar/tiebar, koni yellow, and nuespeed sport springs. I can set the car up to understeer, oversteer, or be nuetral. Its all in the tire pressure, and shock settings.
The swaybar would help get you to a more nuetral ride, which, by your description, is what you want.
An "autocross" alignment also helps with handeling and if you need one it shouldn't cost more.
Old Jul 22, 2002 | 08:19 PM
supergreenNA1's Avatar
New User
Default Re: ? ? ? Sway bar considerations ? ? ? (MattG)
mattg... what do u mean by "autox alignment?"
do you have any experience/recommendations?
Old Jul 23, 2002 | 07:26 AM
osbornsm's Avatar
New User
So if i get the sway bar should i get springs first? I just want to play with oversteer and dont' want a deadly rough ride. I.E. Springs. The Si is pretty tight to start with.
No-Gi
Jun 11, 2004 03:27 PM
gakkuken
21
May 23, 2003 02:29 PM
VTEConly
12
Jul 9, 2002 09:50 AM
EK-Cruiser
Sep 27, 2001 06:37 PM
Alexander
Sep 1, 2001 10:13 PM
