Converting OBDII distributor to OBDI??
Old Jul 23, 2002 | 07:09 PM
boomslang's Avatar
Default Converting OBDII distributor to OBDI??
How do you do this? I know you need the OBDI plugs to solder on, but is that it?
Old Jul 23, 2002 | 10:24 PM
C-speed's Avatar
Default Re: Converting OBDII distributor to OBDI?? (Inlinefour)
yup.. just get the obd1 plug and then cut the old plug off.. all the wire colors are the same from obd2 and obd1, just match them up.
Old Jul 24, 2002 | 04:58 AM
boomslang's Avatar
Default Re: Converting OBDII distributor to OBDI?? (G3-TEG)
Thanks!
Old Jul 24, 2002 | 08:03 PM
Dokta's Avatar
Do you cut off the plug that comes out of the base of the distributor, or the plug on the wiring harness? Which one decides which OBD?
Old Jul 24, 2002 | 08:19 PM
Integra-T's Avatar
Default Re: Converting OBDII distributor to OBDI?? (Dokta)
You cut off the plug on the distributor side dependent on OBD. Say you have OBD2 wiring harness you use OBD2 distributor plug on OBD1 distributor. Vice versa for OBD2 distributor. HTH.
Old Jul 24, 2002 | 08:40 PM
Dokta's Avatar
Default Re: Converting OBDII distributor to OBDI?? (Integra-T)
The reason I ask is because I am swapping an OBDII B20Z into an OBDI 93 civic si. I was going to use an OBDI integra LS ECU. If I want to use the OBDII wiring harness, what do I have to do?
Could I just replace the plug on the distributor side with an OBDI distributor plug and use OBDI fuel injectors?
-or-
Do I have to use an OBDI integra LS wiring harness along with an LS intake manifold and injectors?
Old Jul 25, 2002 | 12:21 AM
salbaje's Avatar
i did this to a swap and ended up buying an obd1. it was throwing a code even though i soldered each wire and car ran but had code
kempWAGON
Feb 16, 2010 06:36 PM
skoodles2k6
Nov 30, 2007 06:48 PM
adictionbass
Dec 1, 2004 02:01 PM
h22acivic4u
Jul 8, 2003 10:18 PM
Blown90hatcH
Feb 11, 2003 01:26 PM
