vx to gsr O2 sensor`
Old Jul 22, 2002 | 03:56 PM
Cashflo's Avatar
Default vx to gsr O2 sensor`
I have a vx hatchback and swapped out for a gsr. When i was going switch out the O2 sensor i noticed that my vx ran five wires and the gsr four. How do I know which wire splices into what. The gsr O2 has 2 white, 1 grey, and 1 black. The vx has orange, yellow, red, white, and black.
Old Jul 22, 2002 | 10:46 PM
Kataku2K3's Avatar
Default Re: vx to gsr O2 sensor` (eghead)
Why not just get the GSR four pin O2 it'll look cleaner then tappin into the VX O2 sensor.
Old Jul 23, 2002 | 03:15 AM
ninesecrx's Avatar
Default Re: vx to gsr O2 sensor` (JDMspecEG6)
The vx is a hard one to wire. It also has 4 main connectors on the passanger side shock tower where as all other hondas have 3. You can use 3 out of the five wires from the stock plug and the 4th wire needs a injector ground pulse. Get it from one of the yellow/black stripe wires in the driverside firewall corner. I dont have exact colors as I know there are 2 different looms for the vx and maybe even 3.....Mike
the vx is a pain in the butt
Old Jul 23, 2002 | 06:22 AM
JHill's Avatar
The VX 5 wire is a UEGO sensor (wide band) because the car was designed to run lean for emissions. I wouldn't mess with trying to use it, the ECU in the VX has a controller built into it to properly scale the UEGO.
Old Jul 23, 2002 | 08:30 AM
hondaeg5's Avatar
Default Re: vx to gsr O2 sensor` (ninesecrx)
oh yes i can agree with this. i still having o2 sensor problems. just dont have the free time to fix it. good luck! let me know what you find. if i happen to find something ill let you know.
WIZDOM
Mar 1, 2008 08:12 PM
TriK
Jul 2, 2003 10:56 AM
92b16vx
May 22, 2003 02:45 PM
G3gsr
May 3, 2003 04:52 PM
bronzehatch
Jul 11, 2002 07:27 AM
