Alignment??
Old Jul 23, 2002 | 05:14 PM
Six2Six's Avatar
Default Alignment??
I just recently did an H22 Swap into a 92 Civic CX. Everything seemed to go fine then when i got it on the road i noticed that the passenger side wheel sat back farther then the drivers side. I fixed that issue by replacing a bent suspension part. Ater i fixed that there is a pretty bad vibration coming from that side of the car. i replaced the Rotor, the tie rod end, the brake caliper and tried several tires. It feels as if the wheel is square. I have yet to get an alignment. Would that make that harsh of a vibration?
Old Jul 23, 2002 | 05:19 PM
Jared's Avatar
Default Re: Alignment?? (gildor)
alignment would not cause such a harsh vibration. sounds like a bent wheel.
Old Jul 23, 2002 | 05:20 PM
Six2Six's Avatar
Default Re: Alignment?? (Jared)
Well thats the thing though, i tried 3 different wheels...
Old Jul 23, 2002 | 06:04 PM
Chiovnidca's Avatar
It could.
Old Jul 23, 2002 | 08:03 PM
Six2Six's Avatar
Default Re: Alignment?? (Chiovnidca)
anyone else have any ideas what it could be?
Old Jul 23, 2002 | 09:36 PM
J T*'s Avatar
the only reason I could see that your alignment would be causing the vibration would be that maybe you 'toe is WAY off, but i don't even think that would do it.
Old Jul 24, 2002 | 09:16 AM
hmonglonertim's Avatar
I had the same problem. It was so shakey I had to drive with 4 hands. Replaced the axle and it solved the issue.
Old Jul 24, 2002 | 09:23 AM
serious's Avatar
Default Re: Alignment?? (hmonglonertim)
yeah, i'd look at the axle as well, especially if you had a bent suspension component.
Old Jul 24, 2002 | 09:38 AM
Six2Six's Avatar
Default Re: Alignment?? (serious)
The axles are new ones from Driveshaft shop. Stage 2 axles, i guess i will give them a call and maybe have them replaced. Also whats the best way to determine that it is an axle problem?
[Modified by gildor, 9:00 PM 7/24/2002]
Old Jul 24, 2002 | 10:53 AM
erniecars's Avatar
replace the axle. Thats all you can do. Id be pretty sure its the axle if it vibrates more turning one direction than the other. if its not the axle, take it back. No loss.
lilboxx
Nov 27, 2012 10:53 AM
moco_machine
Dec 6, 2011 03:12 PM
Show15
11
Jan 21, 2010 09:59 PM
7thgenslug
Honda Civic (2001 - 2005)
12
Jul 14, 2008 03:09 PM
JDMlyfestyle
11
Sep 26, 2005 09:12 PM
