coil overs HELP
Old Jul 22, 2002 | 11:11 PM
Stryker908's Avatar
Default coil overs HELP
Hey all I just got my new set of "number 1" Coil overs for my civic I am sure there are some of you out there that are going to say that they are crap but before these I had a set of APC (ohhh god noooo) coilovers and they worked fine for what I do (daily driving, strip sometimes thats about it ) the problem with all these kits is that they give you all this crap and no instructions so here is a list of parts and what I think they are for please correct me if I am wrong
1) 2 front springs with collars and metal upper mounts : self explanitory
2) 2 rear springs with collars and metal upper mounts : self explanitory
3) 8 large rubber washers : go between the spring and the upper mount ?
4) 4 smaller rubber washers : go between upper mount and shock ?
5) 4 large hex screws : to lock the collar in place
6) 12 small and long hex screws : to lock the collar to the shock
7) 12 small short hex screws : to lock the collar to the shock (smaller shocks)
8) 1 larg bag of rubber rings : to place on your ***** for extended sexual pleasure
that is the list of parts ... the rubber rings I assume go around the shock to stablise the coller agenst it, Do I have these parts right ? thanks !!!!
Old Jul 22, 2002 | 11:47 PM
RedRacerCivic's Avatar
Default Re: coil overs HELP (JDM_SIR_II)
hey i never got #8 for my Skunk 2s!
christianc5692
Suspension & Brakes
May 13, 2011 09:44 PM
96hb
Suspension & Brakes
Mar 29, 2010 07:30 PM
riceforlife
Suspension & Brakes
Dec 15, 2007 03:07 PM
DaChoZn1
Apr 18, 2005 03:18 PM
S13 slide
Feb 8, 2002 10:37 AM
