compression after rebuild?
Old Jul 24, 2002 | 06:45 PM
GruvyTune's Avatar
New User
Default compression after rebuild?
ok, only have like 10 miles on my new rebuild:
b18C1 with 9:1 JE pistons, stock headgasket and arp studs with eagle rods and new valve seals. before rebuild before engine blew i had 190 across the board with 76K on the engine.
after rebuild with lower compression pistons i have 185-190 across the board.
Is that what i should expect with lower compression pistons? I have little signs of any burning oil now so i figure the rings are seated?
did test with cool engine, all plugs out and throttle wide open, i suspect it would be higher if the engine were warm?
thanks!
torin
[Modified by GruvyTune, 10:52 PM 7/24/2002]
Old Jul 24, 2002 | 07:49 PM
1 2 NV's Avatar
Default Re: compression after rebuild? (GruvyTune)
with 10 miles ur rings arent seated yet. put more miles on it and then try it again
aavtec
16
Jul 3, 2013 02:22 PM
95c1v1cs1
Apr 21, 2003 11:29 AM
Brian_92GSR
Aug 1, 2002 08:38 PM
GruvyTune
Jul 24, 2002 09:31 PM
