valve guide?
Old May 3, 2015 | 07:56 PM
1990IntegraLS's Avatar
Icon6 valve guide?
When I adjust the valve clearance on my '90 Integra, the feeler gauge hits a bur on one of my exhaust valves. It's not bad, but I have to pay more attention. It doesn't make any extra noise running either.
What am I hitting. Is it on the valve guide? is that what strikes the adjuster stem? It's not the adjuster, but what is underneath it.
Thanks!
Old May 3, 2015 | 08:11 PM
SpokaneSpeed's Avatar
Default Re: valve guide?
The valve guides are far below that area, I assure you you're not hitting the guide. You should be checking for clearance between the cam lobe and the rocker arm.. you shouldn't be down on the valvestem..
Post a picture with your feeler gauge.. u sure ur in the right area, because it doesn't sound like it
Old May 4, 2015 | 04:23 AM
Whatever is directly under the adjuster.
Old May 5, 2015 | 06:32 PM
Welll... u shouldn't be measuring the clearance UNDER the adjuster.. u should be measuring the clearance above the adjuster - between top of rocker and cam lobe..
Old May 6, 2015 | 03:07 AM
Probably so. I did it 2 wks ago, and it was only the 2nd time on this car....running perfect. None the less, one of the number 2 exhaust valves (or rocker) as a burr where you stick in the feeler gauge. It makes is hard to adjust that valve, but the .008 goes in and .009 doesn't. They all sound the same, so I think it went well.
gsr96cx
Aug 30, 2008 01:24 PM
NA JDM GSR
Oct 17, 2006 10:50 PM
SpoolnByYou
Mar 16, 2006 12:49 PM
FitCRX
Jan 21, 2003 01:21 AM
Cow
Jun 26, 2002 04:12 PM
