piston weight
Old Apr 3, 2015 | 07:21 AM
raverx3m's Avatar
Default piston weight
where is the safe place to grind down a piston.
one of the pistons in a set is 3g heavier than the rest.
npr pistons p73 replacement ones
Old Apr 3, 2015 | 10:28 AM
raverx3m's Avatar
Default Re: piston weight
bump
Old Apr 3, 2015 | 11:24 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
It depends on the specific piston design. Since I have never used that brand piston I can't answer your question. You really need to post pictures of inside the piston (underside where the wrist pin goes).
Old Apr 3, 2015 | 11:32 AM
raverx3m's Avatar
its as type-r replacement. identical to oem type-r piston
I looked at them side by side. same thing
Old Apr 4, 2015 | 04:27 PM
raverx3m's Avatar
stock type-r piston nothing special.
anyone?
Old Apr 5, 2015 | 10:11 AM
DO IT ON ALL FOURS
Post a picture of your specific piston and I will tell you. Unless you are saying it is IDENTICAL in every way shape and form as well as ALL holes. There are sometimes balancing holes from the factory depending on manufacturing and this is why I want to see the picture. Not only for that, but I can circle the areas to remove from. I am just trying to help you, but you make things difficult. OR if it's not that important to you then just take it from wherever.
Old Apr 5, 2015 | 10:37 AM
raverx3m's Avatar
U make things complicated like always
Its identical to stock type-r piston . I dont have it with me bro its at work
Old Apr 6, 2015 | 06:50 AM
DO IT ON ALL FOURS
Ok, well I don't have a picture to show you where then. Typically if there is a balancing hole you enlarge that first. If further material is needed then you start to remove it from around the pin bosses. Be sure to shape everything you touch and BREAK ALL EDGES! This is very important to reduce stress risers.
Old Apr 6, 2015 | 09:55 AM
raverx3m's Avatar
pin boss you talking about between pin hole and back of the piston dome? the thick part?
heres a good picture
maybe my oem itr were not actually oem after all.
if these are oem from inline four then mine were aftermarket already also
both of my pistons are identical casting except the Teflon coated area
and both of them don't have dimples on pin boss like the ones in the picture.
3 grams is alot to remove lol I shaved everywhere. and still down to 2 grams I guess I can grind down a lot more where the dimples are on the picture...
all other pistons are exact weight now. they were within one gramm when I got them except this one.(with piston pins)
Old Apr 6, 2015 | 10:17 AM
DO IT ON ALL FOURS
Well, the pin boss is around the pin and will tie into the strutting. You can cut back on the strutting some too. I would take even amounts from all four sides and blend as needed. Definitely weigh as much as possible once you get the idea of how much you are taking off. You can also remove the raised parts where the holes are. Also, all the ribs on the strutting can be removed. I personally don't like touching the crown without a mill.
Old Apr 6, 2015 | 10:37 AM
raverx3m's Avatar
ok that's what I was wondering. I thought those areas are for pin support and cant be too thin
I only got 1g to go so that can be taken care of with those raised parts
where can I remove material from stock itr rods? since im gonna have to weigh those too once the old pistons are pressed out
Old Apr 6, 2015 | 01:56 PM
DO IT ON ALL FOURS
You can start with the casting seams on each side. If you need more than that then it is open for debate and is usually a touchy subject.
Old Apr 6, 2015 | 03:47 PM
raverx3m's Avatar
you mean for rods right?
got the pistons to exact weight with shuffling the pins around.
have to make a connecting rod scale lol. this **** is not as easy at it looks on the internet.
Old Apr 6, 2015 | 05:15 PM
DO IT ON ALL FOURS
Yes for the rods. I already assumed you weighed all pins to see if there were differences. They are almost always the same due to how they are made.
Old Apr 6, 2015 | 06:03 PM
raverx3m's Avatar
Yea pins are slightly different which is good
I used them to get the total weight of the pistons to exactly same on all 4 without trimming too much.
ZCHondaCRX91
Engine Machining & Assembly
Feb 12, 2019 02:43 AM
EGK20A
Mar 28, 2010 12:04 AM
menkio
Jul 16, 2004 02:59 AM
maka
Apr 6, 2004 07:03 AM
supergreenNA1
Mar 24, 2002 02:19 AM
