need help with routing catch can
Old Apr 1, 2015 | 07:50 AM
Smokehappy13's Avatar
Default need help with routing catch can
I got a 98 ek sedan with a b18b1. The guy says he has the pcv deleted, There is a bolt in the valve cover where the pcv used to be. And on the back of the block he has ran an oil line from one side of the oil filter to the other side. I bought a cheap catch can off ebay but i need help routing the hoses. I dont want to hook it back up to the intake manifold. Is there a way to route the can only to the block? Please help, also car is smoking like a kettle
Old Apr 1, 2015 | 09:24 PM
zerovandez's Avatar
Default Re: need help with routing catch can
Probably smoking because the engine sounds like its all sealed up with no way to breathe and realease blow by gasses/fumes. Why do you want to actually run a catch can vs oem setup?
Old Apr 2, 2015 | 02:03 PM
LTCxD2B's Avatar
Any outlet from the engine into the can and the outlet of the can can just vent to air ...
datoad
Oct 5, 2017 08:31 AM
petwhookie
69
Mar 12, 2010 03:50 PM
chillz03
Mar 13, 2009 04:08 PM
alghafat424
Dec 21, 2004 02:17 PM
PaulB
Oct 27, 2004 08:14 PM
