obd0 to obd1 distributor plug swap?
Old Apr 20, 2015 | 12:18 PM
nyckid's Avatar
Default obd0 to obd1 distributor plug swap?
was wondering will a jdm b16 obd0 dizzy work if i swap the plugs from my bad obd1 dizzy?
both has 2 plugs and the same amount of wires.
Old Apr 20, 2015 | 12:34 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: obd0 to obd1 distributor plug swap?
Rule of thumb, match distributor to ECU. If you're ECU is OBD1 you'll need to verify if a pre-OBD distributor will even work before you swap plugs around.
Old Apr 20, 2015 | 01:02 PM
nyckid's Avatar
chipped p28 ecu
Old Apr 21, 2015 | 02:44 AM
HondaPartsHero's Avatar
Technical Hero
OBD0 distributor won't work with OBD1/2 ECU and vice versa.
Old Apr 22, 2015 | 05:43 AM
nyckid's Avatar
why
Old Apr 22, 2015 | 05:51 AM
1990IntegraLS's Avatar
The ECU doesn't know that distributor. Compatibility in programing is specific. The ECU ROM is only written for very specific parts, which are all different in small or big ways.
There are some ECU systems that are designed to be programed by specialized software and interfaces, but that's a whole different and expensive process.
Old Apr 22, 2015 | 12:57 PM
nyckid's Avatar
do you you think i can swap out the cpk?
Old Apr 23, 2015 | 02:19 AM
Technical Hero
No, crank angle trigger wheel has a different number of teeth. You'll need to find another OBD1 distributor if that is what you had before (you can use an OBD2 but you'll need a distributor adapter).
Old Apr 23, 2015 | 08:52 AM
nyckid's Avatar
sorry meant to say the cyp sensor, the box thats not outline in the pics held by two screws.
7rrivera7
May 14, 2014 03:25 AM
dfanatic86
Mar 5, 2014 05:23 AM
kylesmith3251
Jan 17, 2009 05:47 PM
SikAuto
Dec 28, 2008 12:58 AM
SupraRXZ
Jan 8, 2006 10:37 AM
