b16b o2 sensors connection HELP !
Old Apr 4, 2015 | 06:56 PM
russellgold234's Avatar
Default b16b o2 sensors connection HELP !
Hey honda buddies..
Im new here.. & im desperately in need of help..
Engine - b16b type r
ECU - PCT 003
Vehicle - del sol
PROBLEM #1
Basically my engine redlines at 6800-7k rpm full throttle...
When i should be expecting 8k+..?
Check engine light is ON✔✔
And what i noticed is that both my o2 sensors are disconnected
Secondary o2 (2white,1grey,1black)
Primary o2 (2black,1white & 1green)
PROBLEM #2*
There no actual connectors/plugs on the main harness**NONE
So im desperately asking if all the wires go back to the ECU or which wire goes where
All help will be greatly appreciated..
Feel free to ask any questions..
Im from the Caribbean
Trinidad and Tobago
Last edited by russellgold234; Apr 5, 2015 at 08:23 AM. Reason: i wrote the wrong stuff
Old Apr 5, 2015 | 07:01 AM
SpeedRacerEX-R's Avatar
Default Re: b16b o2 sensors connection HELP !
Sooooo, it's running...., but there's no plugs on the harness? I'm confused....
Old Apr 5, 2015 | 07:22 AM
Hey buddy sorry if u misunderstood..
Update..
I opened up the loom beneath the intake manifold & luckily i found 4 stray wires with matching wire colour with the secondary o2
WIRES
Black - white stripe
Black - yellow stripe
Green
White
Unfortunately im not a
Sure if these wires work
& im still missing the single white wire for the primary o2...
Or can i connect both o2 sensor's white wire together.?
Plz help!!!
Old Apr 5, 2015 | 07:46 AM
2point1's Avatar
Update..
WIRES
Green
White
Plz help!!!
The wire colors you listed are for the primary O2 sensor. The 2nd O2 sensor wire colors are
White/red
Black/yellow
Black/white
Red/yellow
Old Apr 5, 2015 | 08:21 AM
Hey thx alot bro
So i reconnected the 4 wire (primary o2)
And wend down n removed the secondary..
Noticed that 3 wires are broken clean off from the top of the sensor leaving 1 wire hanging...
So actually there's 4 wires on this sensor also... damn : (
WIRES
2 white
1 grey
1 black
Unfortunately i cant seem to find wires on the loom to reconnect...
Now where can this be connected to.?
Hmm.
Old Apr 5, 2015 | 08:59 AM
2point1's Avatar
You shouldn't need the 2nd O2 with the ecu your using just the primary o2is needed. Reset the ecu and see if the check engine light comes on once you hook up the primary O2.
Old Apr 5, 2015 | 01:17 PM
Okay thx..
I reconnected the (primary) o2
CEL remains ON
I used the code light technique by jumping the 2 wires
The CEL quickly blinked once
code #1 - primary o2 sensor
Cam any1 direct me from here..?
houseofgrafix
Aug 16, 2010 08:49 AM
shadowstylz
13
Aug 17, 2003 08:10 PM
Turbo88hatch
Feb 16, 2003 09:21 AM
creuger
Nov 12, 2002 03:11 PM
