jdm itr low compression in 2 cylinders
Old Mar 10, 2015 | 08:21 PM
raverx3m's Avatar
Default jdm itr low compression in 2 cylinders
just got a 96-97 itr block looks like it was boosted lost compression in #2 and #3 cylinder
#2 is at 30psi #3 is at 140 psi
#1 and #4 is at 220
Thats cold compression after sittin outside for probably a year.
trying not to spend too much
Can i re ring 2 cylinders or do i have to put new rings on all4?
And is it possible to check other bearings without disturbing them?
If i pop them off and put them right back
I really dont want to replace all bearings.
Old Mar 11, 2015 | 02:16 AM
Runnerdown's Avatar
Default Re: jdm itr low compression in 2 cylinders
You bought a mystery engine with no idea of what happened to it or what it looks like inside. I'd say before speculating on what to replace, open it up and inspect.
Old Mar 11, 2015 | 10:02 AM
raverx3m's Avatar
I tested compression cold.
I know it was boosted for sure
but under valve cover looks brand new no wear at all and not even a thin layer of sludge
coolant is clean.
oil in cyl #3 exhaust port
Old Mar 14, 2015 | 11:37 AM
devious_yeti's Avatar
Could be a bent valve in cylinder 2, being its that much lower than the rest. Something to think about.
Old Mar 14, 2015 | 12:23 PM
raverx3m's Avatar
broke *** piston lol
but the cylinder wall is not damaged.
the combustion chambers are beat up and 3 of the cylinders
but I already got a set
dmonk87
Dec 3, 2011 05:27 AM
ef9itb
Feb 6, 2011 06:21 AM
sirt_eg
Jun 16, 2009 01:25 PM
imgonnalie2u
Jan 11, 2005 08:05 AM
street dreams
Nov 26, 2004 12:52 AM
