Fuel leak need help
Old Mar 10, 2015 | 05:27 PM
Prado_Dc2's Avatar
Default Fuel leak need help
Hello there. My transmission went out a few months ago so my car has been sitting but I turned it on once every 2 weeks. I turned it on to move it in my driveway and noticed my car was leaking gas. I turned my key (not turning the car on) letting the fuel pump run so I can see where the leak was. Can some one help me out on how to fix this please and thank you. The pics show where the fuel is leaking from.
Old Mar 10, 2015 | 06:43 PM
Prado_Dc2's Avatar
Default Re: Fuel leak need help
This is another pic
Old Mar 10, 2015 | 06:44 PM
Prado_Dc2's Avatar
And another
holmesnmanny's Avatar
The best thing to do is to clean the area up real good. Prime it. Check for new fuel.
Old Mar 11, 2015 | 01:31 PM
Prado_Dc2's Avatar
And if it keeps leaking then what?
Old Mar 11, 2015 | 07:09 PM
Then you know what part to replace ?
Old Mar 12, 2015 | 08:29 AM
Prado_Dc2's Avatar
No I don't know what part that is. Can you help me out? What's the part name?thanks
Old Mar 12, 2015 | 08:36 AM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Like stated above needs to be cleaned and checked..you have the pressure, return and vent lines there.. so first thing is to figure out which one it is
Old Mar 12, 2015 | 09:47 AM
Psychoteen101's Avatar
pretty common for the lines to rot out where those clamps run over them. They will buildup moisture over time and corrode the lines. If you pop off that clamp around the lines, youll probably see which line is bad. At that point, you can either cut the bad section out and splice in a new one or replace the entire line.
Old Mar 12, 2015 | 05:35 PM
Pop open the clamp. Take off the bracket. Clean it. Prime it. Check it.
Honda Parts OEM 30% Off | No Tax!! Outside California | Honda Dealer Parts
to see which line you need
Old Mar 13, 2015 | 12:43 PM
Prado_Dc2's Avatar
Thank you guys for the feed back and info on fixing this I really appreciate it. If I have anymore questions I will let you guys know
BIGef
May 17, 2012 07:11 PM
hmong337
May 23, 2010 07:07 PM
Ty05
Sep 22, 2009 08:38 AM
V-SPEC 1
Jun 30, 2008 11:38 PM
Whig-it
Aug 26, 2004 07:51 PM
