honda powered dune buggy
Old Mar 22, 2015 | 10:44 AM
RST295's Avatar
Default honda powered dune buggy
I am building a ra il buggy powered by an A20 accord engine. I am needing some advise on how to do the wiring. As to which wires in the harness I need for it to start and run. I'm not sure on that part of it. If anyone has some advise or point me in the right direction I would very much appreciate it. Thanks
Old Mar 22, 2015 | 03:17 PM
hondamark35's Avatar
Default Re: honda powered dune buggy
Carbureted or fuel injected?
you really need to be working with an engine wiring diagram for the accord to get this right and do any needed troubleshooting to get it going.
you'll need to wire up the alternator, starter, battery, some ground wires, the distributor coil and ignitor... you'll need more if you're running fuel injected.
Old Mar 22, 2015 | 04:09 PM
RST295's Avatar
Sorry, I failed to mention it was fuel injected. I saved the comp and fuel relay, both fuse boxes. I am going to pick up a Hanes manual this week.
Old Mar 23, 2015 | 04:50 AM
v4lu3s's Avatar
RTFM
i would start with the dash and engine harness from the donor car, get those plugged in together and to the engine, then get your grounds and power source hooked up.
then start with the loose plugs leftover and strip those out with their attached wires. probably a lot of lighting stuff as well as various dash items like ac, radio, etc. verify everything with the factory wiring diagram of course...
that is basically what i did when I wired a d16a6 into a late 70s civic...
Old Mar 23, 2015 | 12:29 PM
RST295's Avatar
Good advise. That would prob be my best option for making sure it's fully wired without missing anything. Then as you said started going thru and removing the excess. That's what I will Do. Thanks again
OterLabb
Oct 14, 2017 03:19 AM
RST295
Mar 22, 2015 10:36 AM
Preludeman1
May 28, 2013 08:49 AM
Setsuna F Seiei
Feb 7, 2005 02:57 PM
