AC Condensor Fan Question AC line
Old Mar 12, 2015 | 06:17 AM
92-CivicLX's Avatar
Default AC Condensor Fan Question AC line
When I was getting new Header installed yesterday, I noticed the line was completely broken off (the one going to the actual AC fan). Is this the ac line I need that connects to the fan??
http://www.ebay.com/itm/A-C-Refrigerant-Discharge-Hose-Discharge-Line-UAC-fits-96-00-Honda-Civic-1-6L-L4-/231460352215?fits=Model%3ACivic
I know there are various AC lines, just making sure if this was the correct one. I have no idea how AC units work so I'm just making sure.
thanks
Old Mar 12, 2015 | 06:41 AM
megarast's Avatar
Default Re: AC Condensor Fan Question AC line
u can have it fix to that would be it or buy that . but u need gas and oil and have clean
Old Mar 12, 2015 | 06:42 AM
92-CivicLX's Avatar
I'm trying to understand your post. The one I linked is the one I need to buy? And I can't get it fixed because the line was completely broken off and bent.
Old Mar 12, 2015 | 06:47 AM
megarast's Avatar
yes thats the right one but let ac mechanic clean it if it has ben open for so long u should alot dirt in ur compressor and u dont want that and if it was broken that means new gas and probably new oil to
Old Mar 12, 2015 | 06:51 AM
92-CivicLX's Avatar
ok great thanks! And do have an answer for my other topic concerning the radiator hoses?
https://honda-tech.com/tech-misc-15/...-swap-3241468/
Old Mar 14, 2015 | 11:13 AM
fcm's Avatar
fcm
Old Fart
A C Refrigerant Discharge Hose Discharge Line UAC Fits 96 00 Honda Civic 1 6L L4 | eBay
thanks
there are no A/C lines going to the condenser fan, the A/C line you show is the discharge line, [low pressure liquid line] it runs from the A/C compressor to the CONDENSER, [not the condenser fan].
If your car is a 92 Civic, the line you show is the wrong one, it is for a 96-00 Civic.
what is the MM&Y of your car, and what engine do you have? 94
Old Mar 14, 2015 | 11:16 AM
megarast1's Avatar
low and hi lines goes to the condenser
Old Mar 15, 2015 | 12:14 PM
fcm's Avatar
fcm
Old Fart
wrong, the low pressure liquid line, [discharge line] goes to the condenser, the the high pressure liquid line, [high side line] runs from the condenser to the evaporator the vapor line, [suction line/low pressure] runs from the evaporator to the compressor. 94
98dxkoupe
Jul 29, 2015 06:07 PM
marcusteg
Jul 21, 2005 12:55 AM
MachAF
Sep 16, 2003 11:58 PM
boostdGS
Jul 21, 2003 12:31 PM
