noob fuel question
Old Mar 15, 2015 | 02:58 PM
00mustanggt's Avatar
Default noob fuel question
I got a 93 hatch, b18c1 headwork done freshened shortblock etc.
Now I want to go e85 but I'm lost on the type of injectors I need? stock fuel rail and injectors tuned on neptune, it started life as a 95 gsr, still have stock rail injectors etc have a walboro 255 aem fpr though.
I don't know if I need to wire in a resistor box or if their is a certain injector style I should be going with or brand, I was thinking 650s going to be e85 and 60-80 wet nitrous kit and retune.
Please help I've searched and just get more confused, I understand how they work just not what I need to order.
Old Mar 17, 2015 | 09:39 AM
scmil95eg's Avatar
Default Re: noob fuel question
You only need a resistor box if you run low resistance injectors (2 to 5 ohms).
The injector size you need is dependent on the HP you want to make.
Short & sweet: for gas N/A [FWHP] * .5 / 4 * 1.15 = optimum injector flow rate in lb/hr
for E85 N/A [FWHP] * .7 / 4 * 1.15 = optimum injector flow rate in lb/hr
As long as you're running a wet nitros kit you don't need to factor that into your injector size. You DO have to factor that into your fuel pump though.
John.CRX
May 21, 2010 10:48 AM
tommikaira
Mar 17, 2009 08:42 AM
Joeski99Si
Nov 14, 2008 10:22 AM
evilcivilian
Oct 6, 2004 10:04 PM
