drag slicks
Old Mar 20, 2015 | 11:56 AM
sadatiel's Avatar
Default drag slicks
what's up,
I have been wondering about getting slicks for my new build but im not sure what size.
SOHC turbo (expected 400-450hp)
I am not sure if I should do 13's, 14's or 15's
I see a lot ppl use different setups. if you guys have tire sizes it would help also.
thanks in advance
Old Mar 20, 2015 | 01:28 PM
fcm's Avatar
fcm
Old Fart
Default Re: drag slicks
A smaller diameter tire increase acceleration a bigger diameter tire will increase top speed.
Keep in mind that is overall diameter not the rims diameter.
With that said, you will need to try diff, sizes to see what works.
I autocross, and use Yokohama O32Rs the first set were 13" but I found that when I spray, [75 shot] I would break free, [spin the tires] replaced them with 14" and it was less of a problem. 94
Old Mar 20, 2015 | 01:32 PM
sadatiel's Avatar
Tha k you for your response. I'm doing for 1/4 mile drag... how do you determine overall diameter?
Old Mar 20, 2015 | 02:03 PM
fcm's Avatar
fcm
Old Fart
A dealer would be able to tell you or you can just measure, I should have mentioned, with that amount of power I would go "big and wide". 94
Old Mar 26, 2015 | 05:20 AM
sadatiel's Avatar
ok I think I have an idea, I appreciate it FCM
Old Mar 26, 2015 | 09:38 PM
devious_yeti's Avatar
Most likely you'll be in the 23" or 24.5" tall slick range. 13" by 9" wide should work. Ask in the drag racing forum.
DIABOLIC8
Aug 21, 2009 04:11 AM
accord99power
Jun 4, 2009 01:45 PM
bignastyb18
Feb 27, 2009 09:30 AM
97grnrs
Mar 14, 2008 08:15 AM
austrian type-R
Apr 8, 2002 07:07 AM
