banged up head fixing?
Old Apr 7, 2015 | 09:55 AM
raverx3m's Avatar
Default banged up head fixing?
got this not knowing whats inside.
getting the block fixed and new pistons.
now im not sure what to do with this
piston broke a chunk off and bounced around .
the worst one.
Old Apr 7, 2015 | 02:41 PM
bspeed's Avatar
Default Re: banged up head fixing?
salvagable, is the repair cost worth the value of the head? Call around to machine shops see what the going rate is. Speedfactory is in Tacoma, they do cylinderhead work.
Old Apr 7, 2015 | 03:12 PM
raverx3m's Avatar
type-r head. if it was b16 probably not worth it
I have a welder that can weld it up for me I just have to clean it up myself.
anyone have a picture of a deshrouded? combustion chamber that I can do on this one to smooth out the small chips?
I mean. how far can I go with dremel before it will change the flow/swirly dramatically?
Old Apr 7, 2015 | 03:14 PM
raverx3m's Avatar
i was also thinking of warming up the head and bump all the small dings flat with a hammer and a punch that way i don't have to take out a lot of material.
Old Apr 7, 2015 | 07:10 PM
Bently_Coop's Avatar
Steve at Heart
Take it to the machine shop on 99 and 112th, Called Jay's. Have him surface it and jet wash it than think about cleaning after that.
Old Apr 7, 2015 | 09:54 PM
raverx3m's Avatar
no need for that its already cleaned. just need to take it to welder.
I wanted to see what people say if I should spend money fixing it since its a type-r head. I have the complete motor. block is already at the machine shop
Old Apr 8, 2015 | 02:53 PM
bspeed's Avatar
Ultimately it's like I said, how much will it cost to repair vs replace. If you take it to a real porter that would offer welding and de-shrouding as services anyway you are going to get a real idea of the cost.
The head is arguably the place Honda's make all their power, get it done right don't home garage diy it.
Old Apr 9, 2015 | 11:28 AM
Dark_Teg's Avatar
My Type R head:
Old Apr 9, 2015 | 06:44 PM
Steve at Heart
^That head has been resurfaced and cleaned. Much better place to stsrt working from.
Old Apr 11, 2015 | 11:07 PM
riceburner700's Avatar
ya its pretty easy blend and fix
Colin
Jun 1, 2013 08:17 PM
818wHtEG6
Apr 21, 2007 06:06 AM
rdwaldo
Jan 10, 2007 03:47 PM
CrX-To-Tha-Max-v2.0
Oct 22, 2004 07:18 PM
Lucifer6i9
Nov 9, 2003 11:05 PM
