distributor problem
Old Apr 10, 2015 | 02:30 PM
mattmaine1991's Avatar
Default distributor problem
So I got a code 4 on my 96 Honda civic hatch obd2 to obd1. The code is ckp which is located in the distributor so I got a new one. Put it on and went to start it and nothing so I checked a few things out and thought let me look at the distributor again. I pulled it and the shaft that goes in the motor the 2 prongs where cut off. Wharf causes that to happen. Is there something wrong with my motor or is it cause the new one had aluminum prongs.
Old Apr 10, 2015 | 03:09 PM
Default Re: distributor problem
I got one prong out of the motor and one went further down. What would be the easiest way to remove that one.
Old Apr 10, 2015 | 04:01 PM
I had the old distributor and it was made of steel. So I toolk both apart and and swapped out the bad on the new and replaced the shaft with the old looks good. All I really needed tl do was swap out the sensors and call it a day but why not use the new. But I am still lime what would cause it so shear off. And help would be greatly appreciate
JBirch_97Prelude
Jun 25, 2006 12:31 PM
93_teg_CT
May 28, 2006 11:26 AM
CWTegRNo.160
Jan 5, 2004 01:14 PM
SleepY2112
Dec 9, 2002 03:46 AM
