03 civic radiator and fluid help
Old Apr 14, 2015 | 12:13 PM
jahwarrior1423's Avatar
Default 03 civic radiator and fluid help
New to the forum.
I have a 03 Civic with a 1.7L with 175k mile that I recently replaced my water pump, new head gasket and had the head rebuilt, T stat replaced and fan temp sensor replaced.
I am wanting to replace my radiator more so for "preventative" maintenance. I found a radiator online for $60 shipped (denso brand) from rock auto and am wondering if that'll be a sufficient replacement or is there a dual core radiator somewhere?...the reason why I want a new radiator because that'll give me basically a all new cooling system.
Also, which radiator fluid should I use?...I see big raves about Honda blue fluid. I would assume I would need to do a total fluid flush from my car to make sure ALL green fluid is out of my current system so I don't get any chance of fluid mix.
What do you guys recommend as for a radiator and which fluid?
Old Apr 14, 2015 | 03:01 PM
SpokaneSpeed's Avatar
Default Re: 03 civic radiator and fluid help
Standard ethylene glycol works just fine (green). If u want to add a water wetter that will help too. Civic radiators are small and are sufficient for cooling, no real need for anything bigger for a stock setup IMO...
PhoebeK
Honda Civic (2006 - 2015)
Sep 9, 2017 10:13 PM
cabdolla
Mar 14, 2012 12:22 PM
BB4lude
18
Mar 10, 2008 05:10 PM
scrubachu
Feb 6, 2003 01:32 PM
TurbothisLS
Oct 6, 2002 05:19 PM
