B15b swap issues.Please help!
Old Apr 26, 2015 | 12:17 PM
514honda's Avatar
Default B15b swap issues.Please help!
Alright guys I recently blew a ring on my 2000 civic with a d16 motor. So I went to my local Jdm and got a new one however stupid me noticed halfway through that they had given a d15b non vtec. Figured might not be a problem so I went through with it I'm not looking to build a race car anyway just an economic daily. there were 2 things I had to change distributor and made a bigger hole for the 2nd o2 sensor started it up and all seemed fine until I went to go drive, it takes a long time to accel I have to rev up to about 3000 rpm to take off normally. I changed the injectors, fuel pressure regulator, and throttle body I'm running out of ideas ... I'm really really hoping I don't have to swap the ecu and wire harness as well but I do have it worse case. Also I had a mechanic change the timing belt and water pump on it maybe he didn't time it properly?
Old Apr 27, 2015 | 01:02 PM
edwinie26's Avatar
Default Re: B15b swap issues.Please help!
Ecu
edwinie26's Avatar
You should fix your title
Old Apr 27, 2015 | 04:15 PM
HondaPartsHero's Avatar
Technical Hero
Check engine light on?
Old Apr 28, 2015 | 06:41 AM
ejv8s10's Avatar
The D15B does not have a crank angle sensor.
Did your original engine have one?
Old Apr 28, 2015 | 07:45 AM
edwinie26's Avatar
Sorry to ask just need to be reassured: Did you get a d15b piston ring/ long block/ block/ or head??
Old Apr 28, 2015 | 08:41 AM
514honda's Avatar
No check engine light
Old Apr 28, 2015 | 08:47 AM
514honda's Avatar
I got the motor complete I have someone checking the timing if its not that I guess maybe ecu which I have for this motor and the wire harness it's weird tho everything plugged up i just had to change back to my original distributor
Old Apr 28, 2015 | 09:57 AM
514honda's Avatar
You know I'm not sure I'm going to look into that I'll get back to you
Old Apr 28, 2015 | 10:07 AM
edwinie26's Avatar
I'm pretty sure obd2 has them,
Ecu is your likely cause. I know you can mess with the ecu and disable the crank on a p72 not sure about others.
If not, You will either have to get an obd1 ecu and a obd2to obd1 adaptor or get a d16 vtec if you can return the d15.
Old Apr 28, 2015 | 01:21 PM
ejv8s10's Avatar
There is a trick to defeat the need for the crank sensor.
.:FFS TechNet:. » ECU & WIRING How-To Articles » CKF Bypass Trick
Old Apr 29, 2015 | 02:09 PM
514honda's Avatar
Thanks a lot guys the mechanic still has my car but I might stop by tomorrow and try the wire splicing if that fails I'll reconnect everything back to normal and just get an adapter since I have the ecu already. fingers crossed!
Old May 2, 2015 | 06:06 AM
514honda's Avatar
So I finally found time to go check up on my car he is going to check the timing today and I asked him about the crank sensor he said he took the one from my original motor and put it on this one so if it's not the timing that's off I'm left clueless
Panzo274
Honda Civic (2001 - 2005)
Apr 24, 2017 09:18 PM
jo dude
Dec 31, 2014 11:50 AM
existanzcivicb20
28
Feb 18, 2014 05:54 AM
dracos2001
Jan 10, 2007 07:49 AM
cJ_EG2
14
Aug 26, 2006 09:41 AM
